Meet the Razer Seiren V3 Mini - an ultra-compact USB microphone that now packs even more. Featuring a tap-to-mute function and advanced audio customization, enjoy studio-quality voice capture with the perfect pint-sized companion for gaming, streaming, and chatting.
Condenser mic for crystal-clear voice capture
Fitted with a custom condenser capsule, the mic's impressive sensitivity can capture more detail especially at higher frequencies, ensuring it broadcasts your voice with stellar clarity and quality. -
Supercardioid pickup pattern for greater voice isolation
A tighter pickup pattern allows the mic to focus on your voice while suppressing room noise, so you'll never have to worry about sounds like typing or mouse clicks getting in the way. -
Tap-to-mute sensor with LED indicator for instant control
Whether you're gaming, chatting, or streaming, instantly prevent audio mishaps by simply tapping the top of the mic, and tell at a glance if the mic is active or not with an LED status indicator. -
Built-in shock absorber to dampen noise
Find your sweet spot with a tiltable mic stand that also features a built-in shock absorber to dampen noise caused by accidental knocks and bumps. Can be detached for a boom arm setup. -
Plug-and-play design for a fuss-free setup
Be ready to game, stream, or chat in seconds. Simply plug the USB mic to your PC and you're good to go - no software or drivers required. -
Advanced customization via Razer Synapse for one-stop audio control
From studio-level sample rates to separate volume mixes for playback and your audience, create the perfect setting and manage it all from one powerful platform.
- Razer Seiren V3 Mini - microphone
- Product Type
- Microphone - USB
- Compatibility
- Windows
- Recommended Use
- Computer - communication, streaming
- Black
- Microphone
- Tabletop
- Microphone Technology
- Condenser
- Microphone Operation Mode
- Super cardioid
- 1-year warranty
- Product Type
- Microphone - USB
- Compatibility
- Windows
- Black
- Recommended Use
- Mute LED indicator, status LED indicator, built-in noise shock absorber
Microphone
- Recommended Placing
- Tabletop
- Condenser
- Super cardioid
- Connectivity Technology
- Wired
- Sensitivity
- -36 dB
- Frequency Response
- 20 - 20000 Hz
- Max Sound Pressure
- 110 dB
- Mute function
Tracking
- Sensors
- Touch sensor
- Connector Type
- USB
- Included Accessories
- USB-C to USB-A cable
- Cable Details
- Supported Host Device OS
- Windows 10 (64-bit)
- Plug and Play
- Limited warranty - 1 year
