Razer Kiyo Pro
Razer Kiyo Pro
Quicklinx: GCV6WS00 Mfr#: RZ19-03640100-R3M1
£141.66 ex VAT
£169.99 inc VAT
Achieve professional video standards for streaming and video conferencing with the Razer Kiyo Pro - an FHD USB webcam that has a high-performance adaptive light sensor, so you can enjoy crisp, clear quality in any setup and lighting condition.
ADVANCED IMAGING. ABSOLUTE FIDELITY
Achieve the highest standards of streaming with the Razer Kiyo Pro—a USB webcam with a high-performance adaptive light sensor for max fidelity at 1080p 60FPS, and the ability to enable HDR at 30FPS. Give your viewers the pro-grade clarity and quality they deserve in any setup and lighting condition.
HIGH-PERFORMANCE ADAPTIVE LIGHT SENSOR
The webcam is driven by a larger Type 1/2.8 ultra-sensitive CMOS sensor with STARVIS™* technology that adapts to any lighting condition, ensuring picture-perfect clarity for any setup.
UNCOMPRESSED 1080P 60FPS
With the highest fidelity that comes with uncompressed Full HD 1080p 60FPS video, your stream will be more engaging and natural to watch with smooth, lifelike quality.
HDR-ENABLED
Make your stream pop with a full spectrum of vibrant colors by activating HDR at 30FPS, which ramps up your video’s dynamic range while correcting over and underexposed areas.
WIDE-ANGLE LENS WITH ADJUSTABLE FOV
Find the right amount of visual space you need to display your showmanship, with a large aperture, wide-angle lens that allows for three field-of-view options selectable via Razer Synapse.
LIGHTNING-FAST USB 3.0
With its plug-and-play USB 3.0 connection, the Razer Kiyo Pro delivers a powerful 5GB/s camera signal to your stream, allowing for maximized video performance with no compression whatsoever.
FLEXIBLE MOUNTING OPTIONS
The stable webcam mount sits snugly on your monitor and can be tilted up or down to find the perfect angle, but can also be detached if you prefer the webcam to be on a tripod setup.
  • Adaptive light sensor
    Fitted with a larger Type 1/2.8 ultra-sensitive CMOS sensor with STARVIS technology, this FHD USB webcam can detect how bright or dark its surroundings are and adjust accordingly for picture-perfect clarity every time.
  • Uncompressed 1080P 60FPS
    As an FHD USB webcam, the Razer Kiyo Pro offers a level of visual fidelity that's as sharp as it is smooth, for the most optimal video quality and viewer experience you can get.
  • HDR-enabled at 30FPS
    Make your stream pop with more vibrant colors by activating HDR at 30FPS, which ramps up your video's dynamic range while correcting over and underexposed areas.
  • Wide-angle lens with adjustable FOV
    From showing off more of your setup and surroundings, to capturing more people in your shot, the large aperture, wide-angle lens allows for three field-of-view options selectable via Razer Synapse.
  • Flexible mounting options
    The stable webcam mount can be tilted to the perfect angle as it sits snugly on your monitor or table, but can also be detached if you prefer the webcam to be on a tripod setup.
  • USB 3.0
    With an easy plug-and-play connection, the Razer Kiyo Pro delivers a powerful 5GB/s camera signal to your stream, allowing for maximized video performance with no compression whatsoever.
  • Privacy cover
    The Razer Kiyo Pro comes with a cover that protects the webcam's lens and gives you the assurance of privacy when not in use.
  • Designed with Corning Gorilla Glass 3
    To improve the image quality, durability and longevity of the Razer Kiyo Pro, its lens is designed with damage- and scratch-resistant Corning Gorilla Glass 3. In lab tests, Gorilla Glass 3 provides up to 4x improvement in scratch resistance when compared to competitive aluminosilicate glasses from other manufacturers.
Razer Kiyo Pro - webcam
Webcam
Audio
Yes: built-in microphone
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
60 frames per second
Video Modes
480p, 720p, 1080p, 360/30p
Optical Sensor Type
2.1 MP
Focus Adjustment
Automatic
USB 3.0
SuperSpeed USB cable - 1.5 m
High Dynamic Range (HDR), privacy shutter, STARVIS sensor, Corning Gorilla Glass 3
Webcam
Audio Support
Wired
Camera
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Video Modes
Digital Video Capture Resolution
1280 x 720, 1920 x 1080
Frame Rate (max)
Image Sensor
2.1 MP
Lens Construction
Focus Adjustment
Automatic
Horizontal Field of View (degree)
103
Vertical Field of View (degree)
80
Diagonal Field of View (degree)
90
Computer Interface
USB 3.0
Ports
USB 3.0
Windows 8 or later
System Requirements Details
Windows 8 - HD 500 MB
Type: Streaming Camera
Brand: Razer
