Achieve professional video standards for streaming and video conferencing with the Razer Kiyo Pro - an FHD USB webcam that has a high-performance adaptive light sensor, so you can enjoy crisp, clear quality in any setup and lighting condition.
ADVANCED IMAGING. ABSOLUTE FIDELITY
Achieve the highest standards of streaming with the Razer Kiyo Pro—a USB webcam with a high-performance adaptive light sensor for max fidelity at 1080p 60FPS, and the ability to enable HDR at 30FPS. Give your viewers the pro-grade clarity and quality they deserve in any setup and lighting condition.
HIGH-PERFORMANCE ADAPTIVE LIGHT SENSOR
The webcam is driven by a larger Type 1/2.8 ultra-sensitive CMOS sensor with STARVIS™* technology that adapts to any lighting condition, ensuring picture-perfect clarity for any setup.
UNCOMPRESSED 1080P 60FPS
With the highest fidelity that comes with uncompressed Full HD 1080p 60FPS video, your stream will be more engaging and natural to watch with smooth, lifelike quality.
HDR-ENABLED
Make your stream pop with a full spectrum of vibrant colors by activating HDR at 30FPS, which ramps up your video’s dynamic range while correcting over and underexposed areas.
WIDE-ANGLE LENS WITH ADJUSTABLE FOV
Find the right amount of visual space you need to display your showmanship, with a large aperture, wide-angle lens that allows for three field-of-view options selectable via Razer Synapse.
LIGHTNING-FAST USB 3.0
With its plug-and-play USB 3.0 connection, the Razer Kiyo Pro delivers a powerful 5GB/s camera signal to your stream, allowing for maximized video performance with no compression whatsoever.
FLEXIBLE MOUNTING OPTIONS
The stable webcam mount sits snugly on your monitor and can be tilted up or down to find the perfect angle, but can also be detached if you prefer the webcam to be on a tripod setup.
Adaptive light sensor
Fitted with a larger Type 1/2.8 ultra-sensitive CMOS sensor with STARVIS technology, this FHD USB webcam can detect how bright or dark its surroundings are and adjust accordingly for picture-perfect clarity every time. -
Uncompressed 1080P 60FPS
As an FHD USB webcam, the Razer Kiyo Pro offers a level of visual fidelity that's as sharp as it is smooth, for the most optimal video quality and viewer experience you can get. -
HDR-enabled at 30FPS
Make your stream pop with more vibrant colors by activating HDR at 30FPS, which ramps up your video's dynamic range while correcting over and underexposed areas. -
Wide-angle lens with adjustable FOV
From showing off more of your setup and surroundings, to capturing more people in your shot, the large aperture, wide-angle lens allows for three field-of-view options selectable via Razer Synapse. -
Flexible mounting options
The stable webcam mount can be tilted to the perfect angle as it sits snugly on your monitor or table, but can also be detached if you prefer the webcam to be on a tripod setup. -
USB 3.0
With an easy plug-and-play connection, the Razer Kiyo Pro delivers a powerful 5GB/s camera signal to your stream, allowing for maximized video performance with no compression whatsoever. -
Privacy cover
The Razer Kiyo Pro comes with a cover that protects the webcam's lens and gives you the assurance of privacy when not in use. -
Designed with Corning Gorilla Glass 3
To improve the image quality, durability and longevity of the Razer Kiyo Pro, its lens is designed with damage- and scratch-resistant Corning Gorilla Glass 3. In lab tests, Gorilla Glass 3 provides up to 4x improvement in scratch resistance when compared to competitive aluminosilicate glasses from other manufacturers.
- Razer Kiyo Pro - webcam
- Webcam
- Audio
- Yes: built-in microphone
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 60 frames per second
- Video Modes
- 480p, 720p, 1080p, 360/30p
- Optical Sensor Type
- 2.1 MP
- Focus Adjustment
- Automatic
- USB 3.0
- Cables Included
- SuperSpeed USB cable - 1.5 m
- High Dynamic Range (HDR), privacy shutter, STARVIS sensor, Corning Gorilla Glass 3
- Webcam
- Audio Support
- Wired
Camera
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Video Modes
- Digital Video Capture Resolution
- 1280 x 720, 1920 x 1080
- Frame Rate (max)
Image Sensor
- 2.1 MP
Lens Construction
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 103
- Vertical Field of View (degree)
- 80
- Diagonal Field of View (degree)
- 90
- Computer Interface
- USB 3.0
- Ports
- USB 3.0
- Cables Included
- OS Required
- Windows 8 or later
- System Requirements Details
- Windows 8 - HD 500 MB
