Enjoy true audio freedom and a pure, uninterrupted listening experience with these advanced earbuds from Razer. With THX Certified sound, advanced hybrid active noise cancellation and a 60ms low latency connection, focusing on your games, music and videos has never been this absolute.
Advanced hybrid active noise cancellation (ANC)
By producing anti-noise to counter any noise it detects from outside and inside your earbuds, the cutting-edge design is able to shut out all distractions and keep you focused on what matters. -
THX Certified true wireless earbuds
Tested and optimized by experts in cinematic audio immersion at THX Ltd., the earbuds present a rich, balanced soundstage for all your movies, music and gaming. -
In-ear design
Get a comfortable, secure, in-ear fit and enhanced noise isolation with Comply foam tips. For even more customized levels of comfort or acoustic options, take your pick from 6 additional sets of silicone tips. -
Activate Gaming Mode to boost the earbuds' wireless performance during competitive games and be quicker to aim or react with audio and video that's more in sync. -
Quick Attention Mode
You can let outside sound in to increase awareness of your surroundings - useful when crossing the road or conversing with other people. -
Touch-enabled controls
Toggle between active noise cancellation and Quick Attention Mode, control your music and calls, and activate your smartphone's voice assistant - all with a few easy taps. -
Up to 20 hours of battery life
Enjoy up to 4 hours of use on a single charge, and power through the rest of the day with a charging case that offers up to 16 more hours of battery life. USB-C charging cable included.
- Razer Hammerhead True Wireless Pro - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Recommended Use
- Portable electronics
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Impedance
- 16 Ohm
- Active Noise Canceling
- Microphone Operation Mode
- Omni-directional, beamforming
- Microphones Included
- 2
- Controls
- Power on/off, answer/end, play/pause, next/previous track, reject call, skip track, pair mode, voice assistant
- 2-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- 53 g
- Recommended Use
- Touch control
- Protection
- Splashproof, waterproof, IPX4
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Bluetooth Audio Codec
- SBC, AAC
- Sound Output Mode
- Stereo
- Active Noise Cancelling Technology
- Advanced Hybrid Active Noise Cancellation
- 20 - 20000 Hz
- Impedance
- 16 Ohm
- Diaphragm
- 10 mm
Microphone
- Form Factor
- Built-in
- 2
- Sensitivity
- -26 dB
- Signal-To-Noise Ratio
- 64 dB
Remote Control
- Controls
Tracking
- Sensors
- Proximity sensor
- Included Accessories
- Pair of Comply foam ear tips, 6 pairs of ear tips, charging case, USB-C charging cable
- Cable Details
- USB-C charge cable - detachable
- THX Certified
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 4 hour(s)
- Run Time Details
- Continuous playback: up to 4 hours , Continuous playback (with included charging case): up to 20 hours
- Limited warranty - 2 years
