The Advanced Model of the Razer Blade 15 features the NVIDIA GeForce RTX graphics and 144 Hz Full HD display for the ultimate gaming experience.
Enjoy immersion like never before on an expansive 15.6" screen consuming nearly 85% of the visible display area, flanked by 4.9mm thin bezels.
Experience real-time ray tracing, artificial intelligence, and programmable shading with the Turing-based GeForce RTX graphics. Go full throttle simultaneously playing and streaming or using the latest creative apps to edit videos.
The Advanced Models of the Razer Blade 15 utilizes a custom vapor chamber and cutting-edge thermal materials to efficiently and quietly dissipate heat for maximum performance and user comfort.
Edge-to-edge action
Enjoy immersion like never before on an expansive 15.6" screen consuming nearly 85% of the visible display area, flanked by 4.9 mm thin bezels. -
With a Full HD, 1920 x 1080 display and refresh rates of up to 144 Hz, on-screen action is incredibly smooth and fluid. With 100% sRGB support, colours are always accurately reproduced. -
Aluminium unibody
Crafted from a single block of aluminium and CNC milled to exact precision, the Razer Blade features a black anodized finish accented by green USB ports and a backlit green triple-headed snake embedded in the display cover. -
Packed with power
Experience real-time ray tracing, artificial intelligence, and programmemable shading with the Turing-based GeForce RTX graphics. Go full throttle simultaneously playing and streaming, or using the latest creative apps to edit videos. -
Innovative vapour chamber cooling system
The Advanced Models of the Razer Blade 15 utilises a custom vapour chamber and cutting-edge thermal materials to efficiently and quietly dissipate heat for maximum performance and user comfort. -
Expand your battlestation
Directly connect up to three external displays for an expansive workspace through Thunderbolt 3, Mini DisplayPort, and HDMI. Complete the setup by connecting desktop peripherals using the three USB 3.1 ports. -
Per-key RGB lighting
The Advanced Model of the Razer Blade 15 is equipped with per-key lighting powered by Razer Chroma. Each key can be individually assigned a colour, allowing for maximum customization and effect options.
- Razer Blade 15 Advanced - 15.6" - Core i7 10875H - 32 GB RAM - 1 TB SSD - UK
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (10th Gen) 10875H / 2.3 GHz (5.1 GHz)
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- 1 TB SSD - NVMe
- Display
- 15.6" 1920 x 1080 / Full HD @ 360 Hz
- Graphics
- NVIDIA GeForce RTX 3080 / Intel UHD Graphics
- Video Memory
- 8 GB GDDR6 SDRAM
- Keyboard
- UK
- Keyboard Backlight
- Yes (RGB)
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2
- Battery
- Up to 7 hours
- Anodized black
- 35.5 cm x 23.5 cm x 1.699 cm
- 2.01 kg
- 1 Year
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 5.1 GHz
- Number of Cores
- 8-core
- Intel Platform Trust Technology (PTT)
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2933 MHz
- Rated Speed
- 2933 MHz
- Slots Qty
- 2
- Empty Slots
- 0
Storage
- Main Storage
- 1 TB SSD M.2 PCIe 3.0 x4 - NVM Express (NVMe)
Display
- 15.6"
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 360 Hz
- Widescreen
- Colour Gamut
- 100% sRGB
- Factory Calibration, 4.9 mm bezel
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 8 GB GDDR6 SDRAM
- Video System Features
- NVIDIA Optimus, NVIDIA GPU Boost 2.0 Technology, NVIDIA G-SYNC, NVIDIA WhisperMode
- Camera
- Yes - 720p
- Resolution
- 1 Megapixel
- Camera Features
- IR camera, Windows Hello
- Sound
- Stereo speakers, array microphone
- THX Spatial Audio
Input
- Keyboard, touchpad
- Yes (RGB)
- Keyboard Layout
- UK
- Precision touchpad, Chroma lighting system, Razer Synapse 3 enabled, N-key rollover, per-key RGB
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6E AX 210
- Technology
- Lithium polymer
- Capacity
- 80 Wh
- Run Time
- Up to 7 hours
AC Adapter
- Output
- 230 Watt
Connections & Expansion
- Slots
- 2 x M.2 (PCI Express 3.0 x4) (1 free)
- USB-C (supports Thunderbolt 3) (Power Delivery 3.0) , 3 x USB 3.2 Gen 2 , HDMI , USB-C 3.2 Gen 2 (Power Delivery 3.0) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SDXC UHS-II Card)
Software
- Software Included
- Razer Synapse 3
- Anodized black
- Illuminated Razer logo, vapor chamber cooling system
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- 2.01 kg
- 1 Year
