Razer BlackWidow Elite - Green Switch - UK
Quicklinx: FVDWWS00 Mfr#: RZ03-02620300-R3W1
The Razer BlackWidow Elite is a gaming keyboard designed for prime performance. A multi-function digital dial provides media controls, and the USB 2.0 and audio pass through allows easy cable management. Play for long hours comfortably with the ergonomic wrist rest, and you can even customize key lighting, bindings, and macros.
  • Gamer keyboard with Razer green switches (tactile and clicky); designed specifically for gaming, Razer mechanical switches provide optimised actuation and reset points so commands are executed with blazing fast responsiveness; engineered for durability up to 80 million keystrokes
  • The Razer BlackWidow Elite delivers full functionality with keyboard controls for everything from brightness to volume via a programmable multi-function digital dial with three tactile media keys
  • The keyboard comes with a magnetic ergonomic wrist rest that snaps to fit at the front of your keyboard and is made of plush leatherette for extreme comfort
  • Every single key of the Razer BlackWidow Elite is customisable, so you can rebind it to another key or function or record multiple keystrokes into a macro
  • Ergonomic wrist rest
    The keyboard comes with a magnetic ergonomic wrist rest that snaps to fit at the front of your keyboard and is made of plush leatherette for extreme comfort.
  • Fully controllable keys
    Every single key of the Razer BlackWidow Elite is customizable, so you can rebind it to another key or function, or record multiple keystrokes into a macro.
  • Engineered for durability
    Razer mechanical switches deliver top performance and durability to make sure you're ahead of your game. The switches are manufactured in-house to ensure strict requirements are met for each switch produced.
Razer BlackWidow Elite - keyboard - black
Keyboard - ergonomic
Backlit
RGB
USB
Wired
Numeric Keypad
Backlit
RGB
USB
Input Device
Keyboard Technology
Mechanical
Anti-ghosting
Palm Rest
Numeric keypad
Key Life Span
80 million clicks
