Razer Anzu - Smart Glasses (Round Blue Light + Sunglass SM)
Quicklinx: GCTKWS00 Mfr#: RZ82-03630800-R3M1
Rethink eyewear with the Razer Anzu - open-ear audio glasses that protect your eyes and immerse your ears. With built-in speakers hidden in its frame, taking in the sights and sounds now has a whole new meaning.
Blue light filtering or polarized sunglass lenses for entertainment, WFH or outdoor activities
Its blue light filter lessens screen glare to protect your eyes, reducing eyestrain so they feel fresh and focused while enjoying entertainment or working, while the polarized replacement lens shields your eyes from the sun. Low latency audio for seamless, immersive sound
Industry-leading 60ms Bluetooth connection delivers smooth, stutter-free sound that allows you to stay immersed without any disruptions from audio delay or skipping
Built-in mic and speakers for hands-free communication wherever you are With the Razer Anzu, you can go hands-free when taking calls thanks to a discreet omnidirectional mic built into its frame.
Touch-enabled and voice-assistant compatible for convenient, intuitive smart controls
Change music tracks, play or pause media, manage calls, and activate your smartphone’s voice assistant—all from the glasses’ sleek touch interface.
More than 5 hours of battery life to power through your day
With this much mileage on a single charge, it’ll never run out during long gaming sessions. When folded up and not in use, it conserves power by shutting off automatically.
  • Advanced eye protection
    Its blue light lenses filter by 35% to protect your eyes, reducing eyestrain so they feel fresh and focused while enjoying entertainment or working, while the polarized replacement lenses shield your eyes from the sun with 99% UVA/UVB protection.
  • Low-latency audio
    Its industry-leading 60ms low-latency Bluetooth connection delivers smooth, stutter-free sound that allows you to stay immersed without any disruptions from audio delay or skipping.
  • Open-ear design
    With the Razer Anzu, you can go hands-free when taking calls thanks to open-ear audio and a discreet omnidirectional mic built into its frame.
  • Touch-enabled and voice assistant compatible
    Change music tracks, play or pause media, manage calls, and activate your smartphone's voice assistant - all from the glasses' sleek touch interface.
  • More than five hours of battery life
    With this much mileage on a single charge, it'll never run out during long sessions. When folded up and not in use, it conserves power by shutting off automatically.
  • Water-resistant IPX4 design
    The Razer Anzu is designed to be splash-proof, so it isn't affected by sweat and will work like a charm after meeting any unfortunate spills or weather.
Razer Anzu - Round Design, Size SM - Blue Light and Sunglass Lens Bundle - headphones with mic
Headphones - Bluetooth - wireless
Compatibility
iPhone, iPad, Android phone, Android tablet
Recommended Use
Portable electronics
Headphones Form Factor
Glasses
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Microphone Operation Mode
Omni-directional
Microphones Included
2
Controls
Answer/end, play/pause, next/previous track, reject call, pair mode, voice assistant, game mode on/off
Compatibility
44 g
Recommended Use
Touch control, auto power on/off
Protection
Splashproof, sweat-resistant, IPX4, water-resistant, UVB protection, UVA protection, blue light filtering
Audio Output
Glasses
Wireless
Wireless Technology
Bluetooth
Sound Output Mode
Stereo
Diaphragm
16 mm
Microphone
Built-in
Omni-directional
2
Remote Control
Controls
Cleaning cloth, carrying case, USB charging cable, polarised lenses, blue light filtering lenses
Cable Details
USB charge cable - detachable
IPX4
Auto On/Off
Headphone battery rechargeable
Run Time (Up To)
5 hour(s)
