Rethink eyewear with the Razer Anzu - open-ear audio glasses that protect your eyes and immerse your ears. With built-in speakers hidden in its frame, taking in the sights and sounds now has a whole new meaning.
Blue light filtering or polarized sunglass lenses for entertainment, WFH or outdoor activities
Its blue light filter lessens screen glare to protect your eyes, reducing eyestrain so they feel fresh and focused while enjoying entertainment or working, while the polarized replacement lens shields your eyes from the sun. Low latency audio for seamless, immersive sound
Industry-leading 60ms Bluetooth connection delivers smooth, stutter-free sound that allows you to stay immersed without any disruptions from audio delay or skipping
Built-in mic and speakers for hands-free communication wherever you are With the Razer Anzu, you can go hands-free when taking calls thanks to a discreet omnidirectional mic built into its frame.
Touch-enabled and voice-assistant compatible for convenient, intuitive smart controls
Change music tracks, play or pause media, manage calls, and activate your smartphone’s voice assistant—all from the glasses’ sleek touch interface.
More than 5 hours of battery life to power through your day
With this much mileage on a single charge, it’ll never run out during long gaming sessions. When folded up and not in use, it conserves power by shutting off automatically.
Advanced eye protection
Its blue light lenses filter by 35% to protect your eyes, reducing eyestrain so they feel fresh and focused while enjoying entertainment or working, while the polarized replacement lenses shield your eyes from the sun with 99% UVA/UVB protection. -
Low-latency audio
Its industry-leading 60ms low-latency Bluetooth connection delivers smooth, stutter-free sound that allows you to stay immersed without any disruptions from audio delay or skipping. -
Open-ear design
With the Razer Anzu, you can go hands-free when taking calls thanks to open-ear audio and a discreet omnidirectional mic built into its frame. -
Touch-enabled and voice assistant compatible
Change music tracks, play or pause media, manage calls, and activate your smartphone's voice assistant - all from the glasses' sleek touch interface. -
More than five hours of battery life
With this much mileage on a single charge, it'll never run out during long sessions. When folded up and not in use, it conserves power by shutting off automatically. -
Water-resistant IPX4 design
The Razer Anzu is designed to be splash-proof, so it isn't affected by sweat and will work like a charm after meeting any unfortunate spills or weather.
- Razer Anzu - Round Design, Size L - Blue Light and Sunglass Lens Bundle - headphones with mic
- Product Type
- Headphones - Bluetooth - wireless
- Compatibility
- iPhone, iPad, Android phone, Android tablet
- Recommended Use
- Portable electronics
- Headphones Form Factor
- Glasses
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Microphone Operation Mode
- Omni-directional
- Microphones Included
- 2
- Controls
- Answer/end, play/pause, next/previous track, reject call, pair mode, voice assistant, game mode on/off
- 2-year warranty
- Product Type
- Compatibility
- 48 g
- Recommended Use
- Touch control, auto power on/off
- Protection
- Splashproof, sweat-resistant, IPX4, water-resistant, UVB protection, UVA protection, blue light filtering
Audio Output
- Glasses
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- Diaphragm
- 16 mm
Microphone
- Form Factor
- Built-in
- Omni-directional
- 2
Remote Control
- Controls
- Included Accessories
- Cleaning cloth, carrying case, USB charging cable, polarised lenses, blue light filtering lenses
- Cable Details
- USB charge cable - detachable
- IPX4
- Auto On/Off
- Battery
- Headphone battery rechargeable
- Run Time (Up To)
- 5 hour(s)
- Limited warranty - 2 years
