Your basket is empty
QuietPC 1.8m Cloverleaf C5 UK Mains Power Cord (Ideal for NUC)
Quicklinx: 8XZTWS00 Mfr#: QPC-MAINSCORD-C5-UK-CLOVER
Type: Power
£6.36 ex VAT
£7.63 inc VAT
Cloverleaf (Type C5) 3-pin AC Mains Power Cords
These high quality 3-pin "Cloverleaf" mains power cords are suitable for a wide variety of external computer power supply blocks such as those supplied with laptops, Intel NUC computers etc.
If you're trying to get a PC to work, the first question you need to ask is, "Is it plugged in?". These top-quality power cords will help you get past that first hurdle! One end of the cable has a "Type C5" connector, which looks like a clover leaf and is often found on external "power bricks" such as those used with laptops and small form factor PCs. At the other end of the cable, a choice of international plugs is available depending on where in the world the PC is going to be used.
Type: Power
Brand: QuietPC
Price Range Ex VAT: 0 - 50
