Quantum's LTO-5 standalone drives are LTFS compatible to archive data in native format. Now including Datastor Deduplication Software providing up to 10x the data per LTO-5 cartridge. The included Datastor Software provides several options for data protection and retention: disk to disk to tape, backup with deduplication to tape or archive to tape in native format. Also compatible with all major backup applications.
- Quantum LTO-5 HH - tape drive - LTO Ultrium - SAS-2
- Tape drive
- Bundled with
- Deduplication Software
- Recording Standard
- LTO Ultrium 5
- Enclosure Type
- External
- Interface Type
- SAS-2
- Key Features
- Encryption
- 21.3 cm x 33.2 cm x 5.8 cm
- 4.3 kg
- Black
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 1.5 TB (native) / 3 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 4, Ultrium 5
- Data Transfer Rate (native)
- 140 MBps (504 GBph)
- Data Transfer Rate (compressed)
- 280 MBps (1008 GBph)
- Power
- AC 120/230 V (50/60 Hz)
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Tape drive - LTO Ultrium
- Bundled with
- LTO Ultrium 5
- Enclosure Type
- External
- Interface Type
- SAS-2
- Key Features
- Encryption
- Built-in Devices
- Led panel
- Enclosure Colour
- Black
- 21.3 cm
- 33.2 cm
- 5.8 cm
- 4.3 kg
Storage Removable
- LTO Ultrium
- Capacity
- Average Seek / Access Time
- 56 sec
- Buffer Size
- 256 MB
- 1 x SAS 6Gb/s - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
- Media Included Qty
- 1
- Included Accessories
- Cleaning cartridge
- Cables Included
- 1 x SAS cable - 2 m
- MTBF
- 250,000 hour(s)
- CSA, UL, WEEE, Directive 2006/66/EC
- Power supply
- Voltage Required
- Limited warranty - parts - 3 years - shipment - response time: 2 business days
- 10 °C
- 40 °C
- 20 - 80% (non-condensing)
