Qsan Technology U400HA-D212 1Gb iSCSI 12 Bay NAS
Quicklinx: B7F6WS00 Mfr#: U400HA-D212
Qsan for years has won many proven records in enterprise market and now TrioNAS LX HA series provides the most cost-effective dual controller solution for enterprise NAS market. TrioNAS LX HA can help you scale capacity, performance, and service availability at the same time and provide zero business downtime in one box.
A breed apart : Dual controller NAS
Image that two cluster nodes are placed in one box with high speed bus connected with each other. This is how TrioNAS LX HAS is designed. The memory caches of both controllers are in mirror all the time using high speed PCI-Express lanes implemented on the backplane, not the cable solution you may see in most cluster environment using commodity server hardware. This is why TrioNAS LX HA has responsive failover time and better performance and efficiency. Moreover TrioNAS LX HA offers a lower total cost solution and flexibility to scale capacity and performance at the same time.
Cache mirroring through high speed bus, not cable solution
Active-active design and support ALUA
Responsive failover time
Easy management to scale performance and capacity
No quorum disk is needed.
More economic than commodity cluster servers
Redundant modular design
RAID controller, fan module, and power supply module are all redundant and hot swappable for maximum availability and easy on-site maintenance. All modules are connected to the backplane circuit board to achieve the most reliable signal transmission and the best aerodynamic thermal efficiency.
ALUA support
ALUA (Asymmetric Logic Unit Access) is supported in TrioNAS LX HA to provide active-active controller mode. Command shipping and data shipping functions are implemented by Qsan in-house technology. This enables higher fault tolerance and better performance and efficiency.
Unified storage with simple management
TrioNAS LX HA consolidates NAS and IP-based iSCSI SAN in one box. Unified storage can help consolidate your IT infrastructure and reduce hardware expenses. You don't need multiple file servers for SMB, NFS, AFP and FTP*. TrioNAS supports all these protocols in one box including iSCSI. TrioNAS LX HA will be your common storage pool that is accessible at either file or block level over existing IP networks. It's the most cost-effective and efficient storage solution.
*AFP and FTP will be supported in the near future.
ZFS and RAID protection
TrioNAS LX HA adopts ZFS file system, which is a transactional, copy-on-write, crash-free file system with 128-bit huge addressing space. ZFS can detect silent data corruption and has self-healing capability and guarantees end-to-end data integrity. There are abundant RAID levels* to choose from to meet application requirements such as redundancy and performance.
SOE & ZVIOS to boost performance
SOE (Samba Offload Engine) and ZVIOS (ZFS Volume IO Scheduler) are Qsan in-house technologies. SOE can greatly improves SMB (Small Message Block) protocol performance. ZVIOS can accelerate block IO such as iSCSI protocol performance.
SSD caching support
TrioNAS LX HA supports using high performance SSD drives as fast storage tiering. SSD caching* can greatly improve random IO performance. You can combine SSD drives and SATA drives as a hybrid storage pool and have a net performance result of a pure SAS storage pool.
Thin provisioning and deduplication
Thin provisioning allows just-in-time capacity and allocates storage space that does not exist. You can delay the hard drive purchase until it is absolutely necessary.
Inline block-level deduplication* provides more efficient way to remove data redundancy and save storage space. For backup and VM application, it can save up to 95% space.
Best Integration of Windows Active Directory
TrioNAS LX HA delivers outstanding integration of Windows Active Directory & LDAP for IT administrators to easily manage accounts. The supports for multiple domains of Windows Active Directory plus the patent-pending UnifiedAUTH empower TrioNAS to provide superior manageability.
Folder and share snapshot
File-level snapshot helps IT administrator to retrieve a file as easy as browsing through a directory when things like virus attack and accidental deletion or modification happens. You can rollback the snapshot to a certain point in time in the past or clone the snapshot to become an independent folder.
LUN snapshot
TrioNAS LX HA supports snapshot for block-level storage such as LUN. Using copy-on-write technology, differential data are recorded between two given points in time. You can rollback the snapshot to a certain point in time in the past or clone the snapshot to become an independent LUN.
Remote replication for disaster recovery
TrioNAS supports both Rsync and block-level snapshot-based replication function. Both of them are asynchronous. Remote replication task can be created for folders and LUNs. Only differential data at block level will be replicated to achieve maximum efficiency.
When disaster strikes at site A, you can quickly switch to site B to make sure business continuity and data security.
TrioNAS LX HA adopts dual controller and fault tolerance design. Both controllers can deliver data services at the same time. It's a genuine active-active design.
RAID controller, fan module, and power supply are all redundant and hot swappable to achieve no single point of failure design.
Network port failover can immediately carry on data services through the mirrored port on peer controller.
Controller failover and online firmware upgrade can provide non-stop data services to protect your valuable data.
Controller failback can be set as manual for flexible management.
  • Fast failover
    Why do you want dual controller NAS? It's because you need an insurance that when one of NAS controllers fails, the data services get the lowest impact, which means the failover time needs to be as short as possible. So the users and applications won't even notice that one of NAS controllers is down. Beacuse heartbeat signal and inter-process communication data are carried out through cable-less, high-speed bus on backplane board, U400HA and U600HA can deliver very responsive failover to keep your mission-critical applications running smoothly. Failover time in TrioNAS LX HA is less than 60 seconds on average. In some cases, it is around 10 to 20 seconds. All data services (SMB, NFS, iSCSI) are protected by controller failover.
  • Unified storage and file sharing center with simple management
    TrioNAS LX HA consolidates NAS and IP-based iSCSI SAN in one box. Unified storage can help consolidate your IT infrastructure and reduce hardware expenses. SMB, NFS, and iSCSI protocols are supported with fault tolerance capability. TrioNAS LX HA can act as your file sharing center for Windows clients and Linux/UNIX clients to exchange files easily. TrioNAS LX HA will be your common storage pool that is accessible at either file or block level over existing IP networks. It's the most cost-effective and efficient storage solution.
  • ZFS and RAID protection
    TrioNAS LX HA adopts ZFS file system, which is a transactional, copy-on-write, crash-free file system with 128-bit huge addressing space. ZFS can detect silent data corruption and has self-healing capability and guarantees end-to-end data integrity. There are abundant RAID levels to choose from to meet application requirements such as redundancy and performance.
  • SSD caching support
    TrioNAS LX HA supports using high performance SSD drives as fast storage tiering. SSD caching can greatly improve random IO performance. You can combine SSD drives and SATA drives as a hybrid storage pool and have a net performance result of a pure SAS storage pool.
  • Hybrid storage for flexibility and performance
    All Qsan NAS product lines can leverage the strengths of SSD drives to become a so-called Hybrid Storage. With SSD caching function, SSD drives act as a fast tier between traditional hard drives and memory to speed up random IO performance.
  • Fail-safe networking
    File-sharing services (SMB and NFS) are provided through cluster IP, which is composed of mirrored network ports from both RAID controllers. So each cluster IP contains dual network paths, one from each RAID controller. Should any network component (port of network switch, cable, network port on RAID controller) along the path fails, the network packets will be quickly switched to the redundant path. The transition is transparent. SMB and NFS file access can continue as if nothing happens at all.
  • Scaled performance
    Because of active-active design, both RAID controllers can provide data services and deliver I/O at the same time. By adding a second controller, dual controller mode is actually 30%~50% faster than its single controller mode in terms of IOPS for small I/O size. Not only do you buy the high availability and insurance plan for data services and your precious data, but you get scaled performance as well.
  • 3x times storage efficiency
    Inline, block-based deduplication helps you remove data redundancy at block level. It's a must-have feature for file backup, data archive, VDI and mail databese applications. It's very easy to use and can be switched on/off at any time without impacting data access. It's a practical function only found in enterprise storage.
  • File-level snapshot
  • Block-level snapshot
  • Remote replication for disaster recovery
    TrioNAS LX HA supports block-level snapshot-based replication function. It is asynchronous. Remote replication task can be created for folders and LUNs. Only differential data at block level will be replicated to achieve maximum efficiency. Replication function is provided by storage array itself. No host server resources are involved and host servers can remain focusing on mission-critical applications.
Qsan TrioNAS LX HA U400HA-D212 - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
12 (max)
44.6 cm x 49.95 cm x 8.8 cm
Storage Controller
2 x RAID SATA 6Gb/s / SAS 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, 60
10Mb LAN, 100Mb LAN, GigE
RAM
32 GB
Power Redundancy
SunSoft Solaris, Apple MacOS, Red Hat Linux 5.0, Red Hat Linux 6.0 or later, Microsoft Windows
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
0 GB
12 (max)
44.6 cm
49.95 cm
8.8 cm
Processor / Memory
RAM
32 GB DDR3
Storage Controller
2 x RAID
Interface Type
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Network / Transport Protocol
NTP, DHCP
Remote Management Protocol
HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), WINS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Hardware compression, trunking, LDAP support, VLAN support, Jumbo Frames support, Samba support, static IP mode, Thin Provisioning, teaming support, Link Aggregation Control Protocol (LACP), cloud backup, SFTP client
Encryption Algorithm
SSL, TLS
IEEE 802.3ad (LACP)
Expansion Bays
12 (total) / 12 (free) x hot-swap
7 x Ethernet 1000Base-T - RJ-45
Built-in 2 cooling fans, deduplication
UL, BSMI, cUL, ICSA Antivirus, CB, FCC, RoHS
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
Power Factor Correction
Limited warranty - 3 years
5 - 95% (non-condensing)
