Your basket is empty
Qsan Technology U300-P21-C316-E3 16Bay 3U NAS 10Gbe
Quicklinx: B9KPWS00 Mfr#: U300-P21-C316-E3
Based on expertise in delivering in-house iSCSI & RAID stack, the TrioNAS LX U300 consolidates NAS and SAN offers multiple enterprise-level features with a competitive price to meet enterprise IT budget and specific needs.
TrioNAS LX U300 series deliver outstanding integration of Windows AD & LDAP for IT administrators to easily manage up to 75536 accounts. The support of Windows ACL simplifies privileges setting and provides access control, helping enterprises to manage IT infrastructures with minimum effort.
The UnifiedAUTH leverages domain authentication (AD, LDAP) to make users seamless access all data services.
With Access Auditing, IT administrators can easily track user and file activities through traceable records to ensure all the files be properly used or modified.
Qsan TrioNAS LX U300-C316 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Enclosure Type
Rack-mountable - 3U
Total Storage Capacity
0 GB
0 (installed) / 16 (max)
44.6 cm x 54.97 cm x 13 cm
30 kg
1 x Intel Xeon E3-1200 v3 series E3-1225V3
Storage Controller
RAID SATA 6Gb/s / SAS 6Gb/s - RAID 0, 1, 5, 6, 10, 50, 60
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
16 GB
Power Redundancy
Microsoft Windows XP, SunSoft Solaris 10, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, SunSoft Solaris 11, Microsoft Windows Server 2012 R2
3 years warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable - 3U
0 GB
44.6 cm
54.97 cm
13 cm
30 kg
Processor / Memory
Processors Installed
RAM
16 GB (installed) / 32 GB (supported)
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Network / Transport Protocol
NTP, iSCSI, FTP, DHCP
Remote Management Protocol
SNMP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), WINS, File Level Security (ACLs), DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
DHCP support, trunking, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, IPv6 support, Access Control List (ACL) support, Jumbo Frames support, teaming support, LACP support, e-mail notification, tagged VLAN
Encryption Algorithm
SSL, TLS
Expansion Bays
16 (total) / 16 (free) x hot-swap
7 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb - SFP+
Wake on LAN, built-in 3 cooling fans
BSMI, FCC, RoHS
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
Power Factor Correction
Software Included
McAfee AntiVirus
Limited warranty - 3 years
5 - 95% (non-condensing)
