TrioNAS LX U400Q is the controller-based unified storage system that integrates NAS and SAN into one chassis. The unified storage system can provide both file-level data access and block-level data access at the same time.
- Qsan TrioNAS LX U400Q-S424 - NAS server - 48 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 4U
- Total Storage Capacity
- 48 TB
- Installed Devices / Modules Qty
- 24 (max)
- 44.6 cm x 49.96 cm x 17.6 cm
- Storage Controller
- RAID SATA 6Gb/s / SAS 6Gb/s RAID RAID 0, 1, 5, 6, 10, 50, 60
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- SunSoft Solaris, Apple MacOS, Red Hat Linux 5.0, Red Hat Linux 6.0 or later, Microsoft Windows
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 48 TB
- 24 (max)
- 44.6 cm
- 49.96 cm
- 17.6 cm
Processor / Memory
- RAM
- 8 GB (installed) / 16 GB (supported) - DDR3
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Hard Drive
- HDD
- Data Link Protocol
- NTP, DHCP
- Remote Management Protocol
- HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), WINS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
- Hardware compression, trunking, LDAP support, VLAN support, Jumbo Frames support, Samba support, static IP mode, Thin Provisioning, teaming support, Link Aggregation Control Protocol (LACP), cloud backup, SFTP client
- Encryption Algorithm
- SSL, TLS
- IEEE 802.3ad (LACP)
- Expansion Bays
- 16 x hot-swap
- 7 x Ethernet 1000Base-T - RJ-45
- Built-in 2 cooling fans, deduplication
- UL, BSMI, cUL, ICSA Antivirus, CB, FCC, RoHS
- Power Device
- Internal power supply
- Installed Qty
- 3
- Voltage Required
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
