Your basket is empty
Qsan Technology TrioNAS LX U400Q-S212 48TB 12 Bay ZFS Rackmount NAS
Quicklinx: 9CGFWS00 Mfr#: U400Q-S212/48TB-RE
TrioNAS LX U400Q is the controller-based unified storage system that integrates NAS and SAN into one chassis. The unified storage system can provide both file-level data access and block-level data access at the same time.
Qsan TrioNAS LX U400Q-S212 - NAS server - 48 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
48 TB
12 (max)
44.6 cm x 49.96 cm x 8.8 cm
Storage Controller
RAID SATA 6Gb/s / SAS 6Gb/s - RAID 0, 1, 5, 6, 10, 50, 60
10Mb LAN, 100Mb LAN, GigE
RAM
8 GB
SunSoft Solaris, Apple MacOS, Red Hat Linux 5.0, Red Hat Linux 6.0 or later, Microsoft Windows
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
48 TB
12 (max)
44.6 cm
49.96 cm
8.8 cm
Processor / Memory
RAM
8 GB (installed) / 16 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Hard Drive
HDD
Network / Transport Protocol
NTP, DHCP
Remote Management Protocol
HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), WINS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Hardware compression, trunking, LDAP support, VLAN support, Jumbo Frames support, Samba support, static IP mode, Thin Provisioning, teaming support, Link Aggregation Control Protocol (LACP), cloud backup, SFTP client
Encryption Algorithm
SSL, TLS
IEEE 802.3ad (LACP)
Expansion Bays
12 x hot-swap
7 x Ethernet 1000Base-T - RJ-45
Power Factor Correction (PFC), built-in 2 cooling fans, deduplication
UL, BSMI, cUL, ICSA Antivirus, CB, FCC, RoHS
Internal power supply
Installed Qty
2
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
Limited warranty - 3 years
5 - 95% (non-condensing)
