AegisSAN Q500-F21 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
- Qsan AegisSAN Q500-F21 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Interface
- 8Gb Fibre Channel, iSCSI (1 GbE)
- Installed Devices / Modules Qty
- 12 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Hard Drive
- 0 no HDD
- OS Required
- Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11, Microsoft Windows Server 2012, Microsoft Windows XP / 7
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 49.95 cm x 8.8 cm
- 25 kg
- 3 years warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Cache / Buffer Size (Max)
- 4 GB (installed) / 8 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
- No HDD
- Capacity
- 0
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
- 4 x 8Gb Fibre Channel , 2 x Ethernet 1000 , 1 x management
- OS Required
- Power Factor Correction (PFC), built-in 2 cooling fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 2 x internal power supply
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- 44.6 cm
- 49.95 cm
- 8.8 cm
- 25 kg
- Limited warranty - 3 years , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
