Your basket is empty
Qsan Technology P600Q-S316 SFP+ 10GbE 16 Bay SAN
Quicklinx: B7GWWS00 Mfr#: P600Q-S316 SFP+
AegisSAN LX P600Q, boasting Intel Xeon processor, is a high availability RAID system offering high performance and supporting SAS & SATA drives. AegisSAN LX P600Q storage features QiSOE (Qsan hardware iSCSI offload engine) and hardware RAID to boost performance and provide superior IOPS & throughput to process tremendously huge amount of random access data for applications like surveillance, video streaming, backup, etc.
Dual active RAID controllers, redundant power supplies, fan modules, and battery backup modules as well as JBOD expansion - all these included in Qsan's P600Q make the iSCSI RAID storage a high availability system.
For better data protection, the top-notch disk array offers copy-on-write snapshot (QSnap), remote replication (QReplica), and battery backup module (BBM) features. It also delivers multiple paths and load balancing functions such as MPIO, MC/S, Trunking, and LACP to better guarantee the reliability and a robust storage environment.
Qsan AegisSAN LX P600Q-S316 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
iSCSI (1 GbE), iSCSI (10 GbE)
16 (max)
Supported Drives
SATA-600 / SAS-2
Built-in Devices
Status LCD
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
0 no HDD - hot-swap
Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Oracle Solaris 10
AC 120/230 V
Power Redundancy
44.6 cm x 49.95 cm x 13 cm
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
Built-in Devices
Status LCD
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
Xeon
Storage Controller
RAID (iSCSI)
Interface Type
Cache / Buffer Size (Max)
4 GB (installed) / 16 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
No HDD - hot-swap
0
Expansion Bays
16 (total) / 16 (free) x hot-swap - 3.5"
2 x Ethernet 1000 , 2 x Ethernet 10Gb - SFP+
Power Factor Correction (PFC), built-in 2 cooling fans
UL, BSMI, cUL, FCC, RoHS
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
44.6 cm
49.95 cm
13 cm
Limited warranty - 3 years , Battery replacement - 1 year
5 - 95% (non-condensing)
