AegisSAN LX series are optimized for different applications, IO sizes, and access patterns. It can deliver more than 600K random IO per second for high IOPS demands and stable 6,200 MB/s for substantial performance requirements.
Qsan array built-in data protection features protect your data under any circumstances without extra charge and without performance impact.
Application optimized performance
AegisSAN LX series are optimized for different applications, IO sizes, and access patterns. It can deliver more than 600K random IO per second for high IOPS demands and stable 6,200 MB/s for substantial performance requirements. -
Enterprise data protections
Qsan array built-in data protection features protect your data under any circumstances without extra charge and without performance impact. -
Smart data management
When the original storage planning or configuration doesn't fit anymore, Qsan smart data management features can recover the status back to normal quickly and minimize the system risk. -
SSD caching
Qsan SSD caching leverages the strengths of both SSDs and SAS/SATA hard drives to cost-effectively meet both high speed and large capacity requirements. It accelerates application performance by utilizing SSD drive as extended RAID controller cache for hot data while most of the cold data are stored in the hard drives. -
Fast rebuild
Qsan Fast Rebuild only rebuilds the partitions with data. With embedded hardware RAID engine, it can greatly reduce the system loading, minimize the performance impact, and reduce rebuilding time as well. -
Thin provisioning
The Thin provisioning feature provides efficient use of total available capacity, centralized management, data protection, flexible storage planning, and automatic extension when allocated space runs out.
- Qsan AegisSAN LX P600Q-D460 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 4U
- Interface
- iSCSI (1 GbE), iSCSI (10 GbE)
- Installed Devices / Modules Qty
- 60 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 2
- Hard Drive
- 0 no HDD - hot-swap
- OS Required
- Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11, Microsoft Windows Server 2012
- Power
- AC 120/230 V
- Power Redundancy
- 48.25 cm x 85 cm x 17.7 cm
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 60
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- CPU
- Xeon
Storage Controller
- RAID (iSCSI)
- Installed Qty
- 2
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Cache / Buffer Size (Max)
- 8 GB (installed) / 16 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- No HDD - hot-swap
- Capacity
- 0
- Expansion Bays
- 60 (total) / 60 (free) x hot-swap - 3.5"
- 4 x Ethernet 1000 , 4 x Ethernet 10Gb - RJ-45
- OS Required
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 3 x internal power supply - hot-plug
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 700 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- 48.25 cm
- 85 cm
- 17.7 cm
- Limited warranty - 3 years , Battery replacement - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
