QSAN P600Q-D424 4U 24 Bay 10GbE SAN, valuable data can be easily safeguarded and synchronized locally and remotely.
Key Features
-Two 10GbE + two 1GbE iSCSI ports per controller
-Up to 780K IOPs & 4000MB/Sec. throughput
-Fully redundant & hot pluggable
-Hardware iSCSI offloaded engine
-Extendable capacity up to 192 hard drives
Provide Great Performance & Efficiency for Mid-range Enterprise
AegisSAN LX P600Q, boasting Intel Xeon processor, is a 10GbE iSCSI, 6G SAS high availability RAID system offering high performance and supporting up to 256 drives. AegisSAN LX P600Q storage includes QiSOE (Qsan hardware iSCSI offload engine) plus QReplica for remote replication. It provides hardware RAID function and superior performance to process tremendously huge amount of random access data.
Dual active RAID controllers, redundant power supplies, fan modules, and battery backup modules as well as JBOD expansion - all these featured in Qsan's P600Q make the iSCSI RAID storage a high availability system and the best solution for industries processing tremendously huge amount of random access data like surveillance, video streaming, backup, etc.
High Availability
P600Q iSCSI system is specially designed for high availability applications. The P600Q has fully redundant components including redundant RAID controllers, power supplies, fan modules, battery backup modules and SAS JBOD expansion ports. All of these components are hot-swappable to create a high availability platform and provide non-stop services. Special features in firmware are RAID 6, 60 support, QSnap writable snapshot, Windows VSS support, and volume configuration restoration. All these features are designed to add an extra layer of protection to your valuable data. To raise the bar higher, P600Q can upgrade firmware without system down time. Both firmware image and volume handling are well protected by the redundant RAID controllers. When one RAID controller is down or disconnected, the other RAID controller will take over all tasks immediately and seamlessly.
Outstanding Performance
With Qsan's latest hardware architecture design plus powerful Intel® C5500/C3500 series processor, P600Q can top the chart with high IOPs and throughput performance. The best breed of its kind! Stability and performance are the mottos we live up to. P600Q can definitely help you deliver more business outputs with less hardware due to consolidation and reduce your energy footprint significantly.
