AegisSAN LX series are optimized for different applications, IO sizes, and access patterns. It can deliver more than 600K random IO per second for high IOPS demands and stable 6,200 MB/s for substantial performance requirements.
Qsan array built-in data protection features protect your data under any circumstances without extra charge and without performance impact.
- Qsan AegisSAN LX P600Q-D316 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 3U
- Interface
- iSCSI (1 GbE), iSCSI (10 GbE)
- Installed Devices / Modules Qty
- 0 (installed) / 16 (max)
- Supported Drives
- SATA-600 / SAS-2
- Built-in Devices
- Status LCD
- Storage Controller
- 2 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Hard Drive
- No HDD - hot-swap
- OS Required
- SuSe Linux, Apple MacOS X, Apple MacOS X / MacOS 9, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, CentOS, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 49.95 cm x 13 cm
- 33 kg
- 3 years warranty
- Hard drive array
- Enclosure Type
Chassis
- Built-in Devices
- Status LCD
- 0
- Supported Devices / Modules Qty
- 16
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- 1 x Xeon
RAM
- Installed Size
- 4 GB
Storage Controller
- 2 x RAID (iSCSI)
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Max Storage Devices Qty
- 256
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
- No HDD - hot-swap
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
- 4 x Ethernet 1000 , 4 x Ethernet 10Gb - SFP+ , 2 x management
- OS Required
- Power Factor Correction (PFC), built-in 4 cooling fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- 44.6 cm
- 49.95 cm
- 13 cm
- 33 kg
- Limited warranty - 3 years , Battery replacement - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
