AegisSAN LX P600Q, boasting Intel Xeon processor, is a 10GbE iSCSI, 6 G SAS high availability RAID system offering high performance and supporting SAS & SATA drives. AegisSAN LX P600Q storage features QiSOE (Qsan hardware iSCSI offload engine) and hardware RAID to boost performance and provide superior IOPS & throughput to process tremendously huge amount of random access data for applications like surveillance, video streaming, backup, etc.
Dual active RAID controllers, redundant power supplies, fan modules, and battery backup modules as well as JBOD expansion - all these included in Qsan's P600Q make the iSCSI RAID storage a high availability system.
For better data protection, the top-notch disk array offers copy-on-write snapshot (QSnap), remote replication (QReplica), and battery backup module (BBM) features. It also delivers multiple paths and load balancing functions such as MPIO, MC/S, Trunking, and LACP to better guarantee the reliability and a robust storage environment.
Application optimized performance
AegisSAN LX series are optimized for different applications, IO sizes, and access patterns. It can deliver more than 600K random IO per second for high IOPS demands and stable 6,200 MB/s for substantial performance requirements. -
Enterprise data protections
Qsan array built-in data protection features protect your data under any circumstances without extra charge and without performance impact. -
Smart data management
When the original storage planning or configuration doesn't fit anymore, Qsan smart data management features can recover the status back to normal quickly and minimize the system risk. -
SSD caching
Qsan SSD caching leverages the strengths of both SSDs and SAS/SATA hard drives to cost-effectively meet both high speed and large capacity requirements. It accelerates application performance by utilizing SSD drive as extended RAID controller cache for hot data while most of the cold data are stored in the hard drives. -
Fast rebuild
Qsan Fast Rebuild only rebuilds the partitions with data. With embedded hardware RAID engine, it can greatly reduce the system loading, minimize the performance impact, and reduce rebuilding time as well. -
Thin provisioning
The Thin provisioning feature provides efficient use of total available capacity, centralized management, data protection, flexible storage planning, and automatic extension when allocated space runs out.
- Qsan AegisSAN LX P600Q-D316 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 3U
- Interface
- iSCSI (1 GbE), iSCSI (10 GbE)
- Maximum LUNs
- 4096
- Installed Devices / Modules Qty
- 0 (installed) / 16 (max)
- Supported Drives
- SATA-600 / SAS-2
- Built-in Devices
- Status LCD
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 2
- Hard Drive
- No HDD - hot-swap
- OS Required
- SuSe Linux, Apple MacOS X, Apple MacOS X / MacOS 9, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, CentOS, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 49.95 cm x 13 cm
- 33 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Built-in Devices
- Status LCD
- 0
- Supported Devices / Modules Qty
- 16
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- Maximum LUNs
- 4096
- CPU
- 1 x Xeon
RAM
- Installed Size
- 4 GB
Storage Controller
- RAID (iSCSI)
- Installed Qty
- 2
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Max Storage Devices Qty
- 256
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- No HDD - hot-swap
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
- 4 x Ethernet 10Gb - RJ-45 , 2 x management - RJ-45 , 4 x Ethernet 1000
- OS Required
- Built-in 4 cooling fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- 44.6 cm
- 49.95 cm
- 13 cm
- 33 kg
- Limited warranty - 3 years , Battery replacement - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
