AegisSAN LX P600Q is a 10 GbE iSCSI, 6G SAS high availability RAID system offering high performance and supporting up to 256 SAS & SATA drives. AegisSAN LX P600Q storage features QiSOE (Qsan hardware iSCSI offload engine) and hardware RAID to boost performance and provide superior IOPS & throughput to process tremendously huge amount of random access data for applications like surveillance, video streaming, backup, etc.
Dual active RAID controllers, redundant power supplies, fan modules, and battery backup modules as well as JBOD expansion - all these included in Qsan's P600Q make the iSCSI RAID storage a high availability system. For better data protection, the top-notch disk array offers copy-on-write snapshot (QSnap), remote replication (QReplica), and battery backup module (BBM) features. It also delivers multiple paths and load balancing functions such as MPIO, MC/S, Trunking, and LACP to better guarantee the reliability and a robust storage environment.
High reliability
P600Q iSCSI system is specially designed for high availability applications. The P600Q has fully redundant components including redundant RAID controllers, power supplies, fan modules, battery backup modules and SAS JBOD expansion ports. All of these components are hot-swappable to create a high availability platform and provide non-stop services. Special features in firmware are RAID 6, 60 support, QSnap writable snapshot, and volume configuration restoration. All these features are designed to add an extra layer of protection to your valuable data. -
Outstanding performance
With Qsan's advanced hardware architecture design plus powerful processor, P600Q can top the chart with high IOPs and throughput performance. P600Q can definitely help you deliver more business outputs with less hardware due to consolidation and reduce your energy footprint significantly. -
Eco-friendly
All P600Q systems are equipped with Qsan's default green features for power saving. In most cases, the hard drives consume most power. With the auto disk spin down feature and proper configuration, the power consumption of hard drives can be reduced to a minimum, and users will not even notice this feature. P600Q monitors the environment temperature for cooling mechanism and the fan modules respond accordingly. The power supply modules are all 80 Plus Gold power efficient for better power converting rate. In virtue of the reduction of hard drive power consumption, the advanced cooling mechanism, and the energy-efficient power supplies, the unnecessary power cost is decreased greatly.
- Qsan AegisSAN LX P600Q-D212 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Interface
- iSCSI (1 GbE), iSCSI (10 GbE)
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- Supported Drives
- SATA-600 / SAS-2
- Built-in Devices
- Status LCD
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 2
- Hard Drive
- No HDD - hot-swap
- OS Required
- SuSe Linux, Apple MacOS X, Apple MacOS X / MacOS 9, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, CentOS, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 49.95 cm x 8.8 cm
- 25 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Built-in Devices
- Status LCD
- 0
- Supported Devices / Modules Qty
- 12
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- CPU
- 1 x Xeon
RAM
- Installed Size
- 4 GB
Storage Controller
- RAID (iSCSI)
- Installed Qty
- 2
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Max Storage Devices Qty
- 256
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- No HDD - hot-swap
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
- 4 x Ethernet 1000 , 4 x Ethernet 10Gb - RJ-45 , 2 x management
- OS Required
- Built-in 4 cooling fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 2 x internal power supply - hot-plug
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- 44.6 cm
- 49.95 cm
- 8.8 cm
- 25 kg
- Limited warranty - 3 years , Battery replacement - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
