Your basket is empty
Qsan Technology P400Q-S316 12prt iSCSI 16 Bay
Quicklinx: B7D9WS00 Mfr#: P400Q-S316
AegisSAN LX P400Q, boasting Intel Xeon processors, is a 1GbE iSCSI, 6G SAS high availability RAID system offering high performance and supporting up to 192 drives. AegisSAN LX P400Q storage includes QiSOE (Qsan Hardware iSCSI offload engine) plus QReplica for remote replication. It provides hardware RAID function and superior performance to process tremendously huge amount of random access data.
  • Fully redundant & hot pluggable designs: RAID controllers, power supplies, fan modules, battery backup modules, & JBOD expansion
  • Six (6) iSCSI ports per controller
  • Hardware iSCSI offloaded engine
  • Green storage designs: auto disk spin down, advanced cooling mechanism, & 80 PLUS energy-efficient power supplies
  • Advanced data protection: RAID 6, 60, QSnap writeable snapshot, Windows VSS support, QReplica remote replication, Volume cloning
  • Flexible volume management for multiple applications & environments: virtualization (VMWare, Hyper-V, Citrix), cloud storage, SQL, Exchange, surveillance, file backup, email, boot from SAN, & etc
  • High connection availability: load balancing & failover
  • Extendable capacity up to 192 hard drives
P400Q iSCSI system is specially designed for high availability applications. The P400Q has fully redundant components including redundant RAID controllers, power supplies, fan modules, battery backup modules and SAS JBOD expansion ports. All of these components are hot-swappable to create a high availability platform and provide non-stop services. Special features in firmware are RAID 6, 60 support, QSnap writable snapshot, Windows VSS support, volume cloning, QReplica remote replication, and volume configuration restoration. All these features are designed to add an extra layer of protection to your valuable data. To raise the bar higher, P400Q can upgrade firmware without system down time. Both firmware image and volume handling are well protected by the redundant RAID controllers. When one RAID controller is down or disconnected, the other RAID controller will take over all tasks immediately and seamlessly.
Qsan AegisSAN LX P400Q-S316 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
iSCSI (1 GbE)
16 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
1 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
No HDD
AC 120/230 V
Power Redundancy
44.6 cm x 49.95 cm x 13 cm
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
iSCSI (1 GbE)
Xeon
Storage Controller
1 x RAID
Interface Type
Cache / Buffer Size (Max)
4 GB (installed) / 16 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
No HDD
Expansion Bays
16 (total) / 16 (free) x hot-swap - 3.5"
6 x Ethernet 1000
Power Factor Correction (PFC), built-in 2 cooling fans
UL, BSMI, cUL, FCC, RoHS
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
44.6 cm
49.95 cm
13 cm
Limited warranty - 3 years , Limited warranty - battery - 1 year
5 - 95% (non-condensing)
