Your basket is empty
Qsan Technology J100 16 Bay Expansion JBOD
Quicklinx: B7DRWS00 Mfr#: J100-C316
J100 supports SAS, SATA and SSD drive configurations, allows IT administrators to flexible deploy system depending on their performance and capacity needs.
With 6G SAS wide ports for host connectivity, J100 provide up to 24 Gb high bandwidth, allowing user to deploy a cost effective JBOD without sacrificing performance.
Compatible with all major RAID card and HBA, J100 can be upgraded to a direct attached storage (DAS), allow users to gain maximum benefits from limited resource.
By utilizing 80 plus gold power supplies, J100 achieve up to 92% power efficiency, allowing users to gain 12% more converting rate than other JBOD in the same segment.
Qsan AegisSAN J100-C316 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
SAS 6Gb/s
16 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
SAS-2 (SATA 6Gb/s / SAS 6Gb/s) - RAID JBOD
Hard Drive
No HDD
AC 120/230 V
Power Redundancy
44.6 cm x 54.97 cm x 13 cm
30 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
SAS 6Gb/s
Storage Controller
SAS-2
Interface Type
RAID Level
JBOD
Hard Drive
No HDD
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
1 x SAS 6Gb/s (input) - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088) , 1 x SAS 6Gb/s (output) - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
Built-in 3 cooling fans
UL, BSMI, cUL, FCC, RoHS
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
Power Factor Correction
44.6 cm
54.97 cm
13 cm
30 kg
Limited warranty - 3 years
5 - 95% (non-condensing)
