Your basket is empty
Qsan Technology F630Q-D316 16Gb FC 16 Bay SAN
Quicklinx: B7GKWS00 Mfr#: F630Q-D316
Fibre Channel array QSAN company equipped with a hardware controller Fiber Channel (FC), iSCSI and RAID. Fibre Channel Array is the ideal tool for creating high-performance SAN infrastructure based on fiber-optic technology. Array Fibre Channel hard disk drives SAS / SATA with up to 4TB, allowing you to create a volume of up to 48TB. Fibre Channel array supports 6Gb SAS / SATA, expandable to 256 discs. The standard version has a Fibre Channel array 2 ports 16Gbit / s Fibre Channel ports and two 1Gbit / s iSCSI connections (one controller) with the ability to employ the full redundancy to provide an instance of the second controller (if we have 4 ports 16Gbit / s FC and 4 ports 1Gbit / s iSCSI).
Qsan AegisSAN LX F630Q-D316 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
iSCSI, 16Gb Fibre Channel
16 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
2 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, 60
Hard Drive
0 no HDD - hot-swap
AC 120/230 V
Power Redundancy
44.6 cm x 49.95 cm x 13 cm
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
Storage Controller
2 x RAID (16Gb Fibre Channel / iSCSI)
Interface Type
Cache / Buffer Size (Max)
4 GB (installed) / 16 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, RAID 60
Hard Drive
No HDD - hot-swap
0
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
4 x 16Gb Fibre Channel , 4 x Ethernet 1000
Power Factor Correction (PFC), built-in 2 cooling fans
UL, BSMI, cUL, FCC, RoHS
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
44.6 cm
49.95 cm
13 cm
Limited warranty - 3 years
