Your basket is empty
Qsan Technology F630Q-D212 16Gb FC 12 Bay SAN
Quicklinx: B7GLWS00 Mfr#: F630Q-D212
AegisSAN LX series are optimized for different applications, IO sizes, and access patterns. It can deliver more than 600K random IO per second for high IOPS demands and stable 6,200 MB/s for substantial performance requirements.
Qsan array built-in data protection features protect your data under any circumstances without extra charge and without performance impact.
Qsan AegisSAN LX F630Q-D212 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
iSCSI, 16Gb Fibre Channel
12 (max)
Supported Drives
SATA-600 / SAS-2
Built-in Devices
Status LCD
Storage Controller
2 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, 60
Hard Drive
0 no HDD - hot-swap
AC 120/230 V
Power Redundancy
44.6 cm x 49.96 cm x 8.8 cm
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
Built-in Devices
Status LCD
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
Storage Controller
2 x RAID (16Gb Fibre Channel / iSCSI)
Interface Type
Cache / Buffer Size (Max)
4 GB (installed) / 16 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, RAID 60
Hard Drive
No HDD - hot-swap
0
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
4 x 16Gb Fibre Channel , 4 x Ethernet 1000
Power Factor Correction (PFC), built-in 2 cooling fans
UL, BSMI, cUL, FCC, RoHS
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
44.6 cm
49.96 cm
8.8 cm
Limited warranty - 3 years
