AegisSAN LX P600Q, boasting Intel Xeon processor, is a 10GbE iSCSI, 6 G SAS high availability RAID system offering high performance and supporting SAS & SATA drives. AegisSAN LX P600Q storage features QiSOE (Qsan hardware iSCSI offload engine) and hardware RAID to boost performance and provide superior IOPS & throughput to process tremendously huge amount of random access data for applications like surveillance, video streaming, backup, etc.
Dual active RAID controllers, redundant power supplies, fan modules, and battery backup modules as well as JBOD expansion - all these included in Qsan's P600Q make the iSCSI RAID storage a high availability system.
For better data protection, the top-notch disk array offers copy-on-write snapshot (QSnap), remote replication (QReplica), and battery backup module (BBM) features. It also delivers multiple paths and load balancing functions such as MPIO, MC/S, Trunking, and LACP to better guarantee the reliability and a robust storage environment.
High availability
P600Q iSCSI system is specially designed for high availability applications. The P600Q has fully redundant components including redundant RAID controllers, power supplies, fan modules, battery backup modules and SAS JBOD expansion ports. All of these components are hot-swappable to create a high availability platform and provide non-stop services. Special features in firmware are RAID 6, 60 support, QSnap writable snapshot, Windows VSS support, and volume configuration restoration. All these features are designed to add an extra layer of protection to your valuable data. To raise the bar higher, P600Q can upgrade firmware without system down time. Both firmware image and volume handling are well protected by the redundant RAID controllers. When one RAID controller is down or disconnected, the other RAID controller will take over all tasks immediately and seamlessly. -
Outstanding performance
With Qsan's hardware architecture design plus powerful Intel processor, P600Q can top the chart with high IOPs and throughput performance. The best breed of its kind! Stability and performance are the mottos you live up to. P600Q can definitely help you deliver more business outputs with less hardware due to consolidation and reduce your energy footprint significantly. -
Green
All P600Q systems are equipped with Qsan's default green features for power saving. In most cases, the hard drives consume most power. With the auto disk spin down feature and proper configuration, the power consumption of hard drives can be reduced to a minimum, and users will not even notice this feature. P600Q monitors the environment temperature for cooling mechanism and the fan modules respond accordingly. The power supply modules are all 80 Plus Gold power efficient for better power converting rate. In virtue of the reduction of hard drive power consumption, the advanced cooling mechanism, and the energy-efficient power supplies, the unnecessary power cost is decreased greatly.
- Qsan AegisSAN LX F600Q-D316 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 3U
- Interface
- 8Gb Fibre Channel, iSCSI (1 GbE)
- Installed Devices / Modules Qty
- 16 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 2
- Hard Drive
- No HDD
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 49.95 cm x 13 cm
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 16
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
Storage Controller
- RAID
- Installed Qty
- 2
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Cache / Buffer Size (Max)
- 4 GB (installed) / 16 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- No HDD
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap - 3.5"
- 4 x 8Gb Fibre Channel , 2 x Ethernet 1000
- Built-in 2 cooling fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 2 x internal power supply
- Max Supported Qty
- 2
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- 44.6 cm
- 49.95 cm
- 13 cm
- Limited warranty - 3 years , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
