AegisSAN Q500-F30 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
Fiber channel interface
The frame-lossless characteristics of fiber channel and multi paths as well as load balance features enable AegisSAN Q500FC series to deliver outstanding performance and satisfactorily handle demanding transactional workloads without worries of packet loss and single point of failure. The disk array offers a robust storage environment for the running services. -
High availability
The dual active controllers plus fully redundant and hot-swappable designs make AegisSAN Q500 series system a highly available system. It offers multiple paths and load balancing features such as MPIO, MC/S, Trunking, and LACP to better ensure the reliability. -
Green designs
AegisSAN Q500 disk array adopts Intel's S1200 series CPU and it's the SAN solution with outstanding energy efficiency and cost effectiveness. This platform includes key features such as error code correction, 64-bit support and virtualization technologies. In addition, AegisSAN Q500 system is equipped with 80 Plus Gold power supplies to achieve 90% energy efficiency as well as peak reduction and improved power quality. The auto disk spin down function enables the system to reduce power consumption of hard drives which account for the most electricity in the storage system. -
Enhanced data security
The innovated USB LCM allows AegisSAN Q500 storage to avoid data leakage in data centers, lower TCO and enhance the manageability for IT administrators. This series includes QSnap for writeable snapshot and QReplica for remote replication to maximize customers' return on investment. The battery backup module keeps cache data safe in the event of power outage. -
Great performance & efficiency
The proprietary QiSOE (Qsan hardware iSCSI offload engine) boosts the performance for the disk array. The outstanding designs of the controllers make AegisSAN Q500 series system provide great IOPS and throughput for performance demanding applications. The hardware RAID makes the reliability better and volume robust.
- Qsan AegisSAN Q500-F30 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 4U
- Interface
- iSCSI (1 GbE), 16Gb Fibre Channel
- Installed Devices / Modules Qty
- 24 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Storage Controller Quantity
- 2
- Hard Drive
- No HDD
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 49.95 cm x 17.6 cm
- 37 kg
- 3-year warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 24
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
Storage Controller
- RAID
- Installed Qty
- 2
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Cache / Buffer Size (Max)
- 4 GB (installed) / 8 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Storage Controller (2nd)
- Installed Qty
- 2
Hard Drive
- No HDD
- Expansion Bays
- 24 (total) / 24 (free) x hot-swap - 2.5" / 3.5" shared
- 4 x 16Gb Fibre Channel , 4 x Ethernet 1000 , 2 x management
- Built-in 2 cooling fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 3 x internal power supply
- Max Supported Qty
- 3
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Power Factor Correction
- 44.6 cm
- 49.95 cm
- 17.6 cm
- 37 kg
- Limited warranty - 3 years , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
