AegisSAN Q500-F20 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
- Qsan AegisSAN Q500-F20 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 4U
- Interface
- 8Gb Fibre Channel, iSCSI (1 GbE)
- Installed Devices / Modules Qty
- 24 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- 2 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- Hard Drive
- No HDD
- Power
- AC 120/230 V
- Power Redundancy
- 44.6 cm x 49.95 cm x 17.6 cm
- 37 kg
- 3 years warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 24
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
Storage Controller
- 2 x RAID
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Cache / Buffer Size (Max)
- 4 GB (installed) / 8 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
- No HDD
- Expansion Bays
- 24 (total) / 24 (free) x hot-swap - 2.5" / 3.5" shared
- 4 x 8Gb Fibre Channel , 4 x Ethernet 1000 , 2 x management
- Power Factor Correction (PFC), built-in 2 cooling fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 3 x internal power supply
- Max Supported Qty
- 3
- Power Redundancy
- Voltage Required
- AC 120/230 V
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- 44.6 cm
- 49.95 cm
- 17.6 cm
- 37 kg
- Limited warranty - 3 years , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
