Your basket is empty
Qsan Technology 16 Bay Q500-P20-S316 10GbE SFP+
Quicklinx: B7CFWS00 Mfr#: Q500-P20-S316
AegisSAN Q500-P20 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
Qsan AegisSAN Q500-P20 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
iSCSI (1 GbE), iSCSI (10 GbE)
Maximum LUNs
2048
0 (installed) / 16 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
Hard Drive
0 no HDD - hot-swap
Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Oracle Solaris 10, Oracle Solaris 11, Microsoft Windows Server 2012, Microsoft Windows XP / 7
AC 120/230 V
Power Redundancy
44.6 cm x 49.95 cm x 13 cm
33 kg
3 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
0
Supported Devices / Modules Qty
16
Supported Drives
SATA-600 / SAS-2
Storage
HDD Array External Interface
Maximum LUNs
2048
Storage Controller
RAID (iSCSI)
Interface Type
Cache / Buffer Size (Max)
4 GB (installed) / 8 GB (max)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
Hard Drive
No HDD - hot-swap
0
Expansion Bays
16 (total) / 16 (free) x hot-swap - 2.5" / 3.5" shared
2 x Ethernet 10Gb - SFP+ , 2 x Ethernet 1000 , 1 x Ethernet 1000 (management)
Power Factor Correction (PFC), built-in 2 cooling fans, upgradable to dual controller
UL, BSMI, cUL, FCC, RoHS
2 x internal power supply
Max Supported Qty
2
Power Redundancy
AC 120/230 V
Power Provided
550 Watt
80 PLUS Certification
80 PLUS Gold
44.6 cm
49.95 cm
13 cm
33 kg
Limited warranty - 3 years , Battery replacement - 1 year
5 - 95% (non-condensing)
