AegisSAN Q500-P10 is the cutting-edge storage system designed to help users do more with less with the top-notch hardware configurations, dual active controllers, fully modular components as well as the state-of-the-art software functions.
- Qsan AegisSAN Q500-P10-D316 - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 3U
- Interface
- iSCSI (1 GbE)
- Installed Devices / Modules Qty
- 16 (max)
- Supported Drives
- SATA-600 / SAS-2
- Storage Controller
- 2 x RAID (SATA 6Gb/s / SAS 6Gb/s) - RAID 0, 1, 3, 5, 6, 10, 30, 50, JBOD, 0+1, 60
- OS Required
- SunSoft Solaris 10, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2008, Red Hat Enterprise Linux 6, Microsoft Windows Server 2012, SunSoft Solaris 11, Microsoft Windows XP / 7
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- 44.6 cm x 49.95 cm x 13 cm
- 33 kg
- 3 years warranty
- Hard drive array
- Enclosure Type
Chassis
- Supported Devices / Modules Qty
- 16
- Supported Drives
- SATA-600 / SAS-2
Storage
- HDD Array External Interface
- iSCSI (1 GbE)
Storage Controller
- 2 x RAID (iSCSI)
- Interface Type
- SATA 6Gb/s / SAS 6Gb/s
- Data Transfer Rate
- 600 MBps
- Cache / Buffer Size (Max)
- 8 GB (installed) / 16 GB (max)
- RAID Level
- RAID 0, RAID 1, RAID 3, RAID 5, RAID 6, RAID 10, RAID 30, RAID 50, JBOD, RAID 0+1, RAID 60
- Expansion Bays
- 16 (total) / 16 (free) x hot-swap
- 12 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 1000Base-T (management) - RJ-45
- OS Required
- Built-in 2 cooling fans, hot-swappable fans
- UL, BSMI, cUL, FCC, RoHS
- Power Device
- 2 x internal power supply - hot-plug
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 550 Watt
- 80 PLUS Certification
- 80 PLUS
- Power Factor Correction
- 44.6 cm
- 49.95 cm
- 13 cm
- 33 kg
- Limited warranty - 3 years , Limited warranty - battery - 1 year
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
