Pro Gaming Backlit Mechanical Keyboard
Unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the MK-85 feature true mechanical switches with unmatched accuracy and feel. No more pressing with full-force in order to activate the keys.The QPAD keyboard will respond to your every stroke in an instant.
Other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. The key switches on MK-85 are built to last 50 million strokes, and the QPAD mechanical key technology provides distinct feedback and puts you in absolute control. The travel distance of the keys is set to 4mm with an actuation point at 2mm.
For gamers, it's all about the feel and functionallity and that is where the QPAD MK-85 truly shines. With a full size keyboard layout in 3 sections, gaming profiles, macro recording, mechanical key switches, media keys and full N-Key roll over via USB, it's the perfect gaming keyboard. Nuff said...
Arguably the best gaming keyboard ever made. Our top-of-the-line gaming keyboard sports the following key-features:
- Full N-Key roll over via USB
- Cherry MX Blue mechanical switch technology
- Ultra-durable, programmable keys, designed to last 50 million strokes
- Individual LED back light on every key for enhanced visuals
- Gold plated USB connectors for extremely low latency
- Media keys for volume control, play, pause and skip tracks
- USB Hub with two high speed USB 2.0 ports
- QPAD MK-85 - keyboard - UK
- Keyboard
- Backlit
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Function
- Programmable, volume, play/pause, skip tracks
- Full-N-key rollover, Cherry MX technology, detachable wrist rest, 2-port USB hub, 2-port USB 2.0 hub, tilt legs, profiles support, N-Key rollover, gold-plated connector, adjustable brightness, braided cable, CHERRY MX Blue technology
- 44.8 cm x 14.9 cm x 3.5 cm
- 1.27 kg
- 2-year warranty
- Keyboard
- Backlit
- Interface
- USB
Input Device
- Hot Keys Function
- UK
- Keyboard Technology
- Mechanical
- 44.8 cm
- 14.9 cm
- 3.5 cm
- 1.27 kg
- 2 x USB 2.0 , 2 x USB , Headphone output , Microphone input
- Included Accessories
- Key removal tool, 4 keycaps
- Cables Included
- 1 x USB cable - 1.8 m
- OS Required
- Microsoft Windows Vista / XP / 7
- Limited warranty - 2 years
