Powered by the Intel dual-core processor and 4 GB of memory, it delivers high performance at a throughput rate of 330 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 6-bay VS-6116 Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-6116 Pro+ can support large storage capacity, with 4TB on each hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard, Sanyo Denki system fan, and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-6116 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
Megapixel recordings
The VioStor NVR supports megapixel recordings (up to 10-megapixel) from various IP cameras. -
Real-time digital watermarking
The VioStor NVR supports real-time digital watermarking to protect the videos and snapshots from unauthorized modifications. The watermark proof utility is provided to verify whether or not the videos and snapshots are original. -
High resolution local display
The VioStor NVR provides an HDMI port which can be connected to an HDMI monitor or TV for doing monitoring in the full HD (1920 x 1080) resolution. -
Convenient control of PTZ and speed dome cameras
The PTZ (Pan/Tilt/Zoom) cameras can be adjusted directly and the preset positions of the IP cameras can be viewed on the local display interface of the VioStor NVR. -
Digital zoom
Digital zoom (in/out) of the video image is supported on the monitoring and playback interfaces of the NVR. -
On-screen event alert
When an event occurs, an alert icon will be shown instantly on the local monitoring page. The alert details can be viewed by clicking the alert icon. -
Multi-server monitoring
Connect to one VioStor NVR and monitor up to 128 channels from other VioStor NVR servers over the LAN or WAN via an IE browser. -
Smart Control of PTZ & Speed Dome Cameras
The PTZ (Pan/Tilt/Zoom) cameras can be directly adjusted by the web user interface of the VioStor NVR. -
Preset position control and auto cruising
The preset positions of an IP camera can be viewed by clicking the corresponding number buttons on the monitoring page. The time interval can also be configured on the PTZ cameras to perform periodic monitoring. -
Instant event notification
When the alarm recording is enabled and an event occurs, an alarm icon will be shown instantly on the monitoring page. The alert details can be viewed by clicking the icon. -
Multi-view playback
Use the multi-view playback feature to divide a video equally into multiple sessions for doing playback in a multi-view window, or play the videos of multiple IP cameras in the multi-view window simultaneously. -
Scheduled remote replication
The VioStor NVR supports scheduled remote replication for performing secure data backup to a remote QNAP NAS on the local network. -
One touch auto video backup
Configure the one touch auto video backup button at the front of the NVR to copy the data from the NVR to an external storage device when the button is pressed. -
Intel CPU and DDRIII memory for superior system performance
Powered by the Intel CPU and DDRIII memory, the VioStor NVR delivers superior performance for surveillance applications. -
CPU thermal solution with fan-less design
Fan-less design provides better performance, quiet operation, lower energy costs, and enhanced reliability. -
S.M.A.R.T. & advanced HDD Health Scanning (HHS)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) helps monitor the hard disk drives status. The VioStor NVR supports HHS (HDD Health Scan) for doing disk checking and bad blocks scanning.
- QNAP VioStor VS-6116 Pro+ NVR - standalone NVR - 16 channels
- NVR - 16 channels - networked
- IP Cameras Supported
- 16
- Frame Rate
- 30 fps
- Compression Format
- MJPEG, MPEG-4, H.264
- Image Resolution
- 1920x1080
- Hard Drive(s) Supported
- Quantity: 6
- Voltage
- 100 - 240 V
- 26 cm x 23.5 cm x 18.5 cm
- 5.7 kg
- Country Kits
- United Kingdom
- NVR
- Video Channels
- 16
- 16
- Image Resolution
- 1920x1080
- Package Content
- Manual, DVR, software, cables, mounting kit, DVR key
- Cables Included
- Network cable - RJ-45 - RJ-45 - 2 pcs.
- Software Included (Y)
- QNAP Finder, Drivers & Utilities
- Country Kits
- United Kingdom
- VCCI, BSMI, FCC
Security DVR
- Frame Rate (Record)
- 30 fps
- Display Modes
- 6 split screens, 9 split screens, 8 split screens, 16 split screens, 4 split screens, 10 split screens, 12 split screens
- Playback Search
- Date / time, event
- Record Events
- Alarm, scheduled, manual
- Networked
- RAID 5 support, RAID 0 support, RAID 1 support, JBOD support, RAID 5 hot spare support, RAID 6 support, watermark, Pan/Tilt/Zoom support, motion detection, key lock, security lock slot (cable lock sold separately), built-in LCD panel
Hard Drive
- Quantity Supported
- 6
- Interface
- Serial ATA
- Removable
- DDNS Support
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UPnP, SMB
- Load balancing
- Video Output Ports
- HDMI x 1
- Network Port
- 10/100/1000Base-T x 2
- Other Ports
- USB 2.0 x 5, VGA x 1, USB 3.0 x 2
- Voltage
- 100 - 240 V
- Frequency
- 50/60 Hz
- Power Consumption
- 91 Watt
- 26 cm
- 23.5 cm
- 18.5 cm
- 5.7 kg
- 0 °C
- 40 °C
- 0 - 95%
