Product
QNAP VS-4116 Pro+ 16 Channel 4 Bay Desktop NVR NAS
Quicklinx: B53WWS00 Mfr#: VS-4116-PRO+-UK
Powered by the Intel dual-core processor and large memory, it delivers high performance at a throughput rate of 250 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 4-bay VS-4116 Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-4116 Pro+ can support up to 16 TB of storage capacity, with 4 TB on each hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The server-grade mainboard, Sanyo Denki system fan, and heat pipe with fanless design assure the solid reliability for maximized system uptime. Moreover, the VS-4116 Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
  • Megapixel recordings
    The VioStor NVR supports megapixel recordings from various IP cameras.
  • Real-time digital watermarking
    The VioStor NVR supports real-time digital watermarking to protect the videos and snapshots from unauthorized modifications. The watermark proof utility is provided to verify whether or not the videos and snapshots are original.
  • High resolution local display
    The VioStor NVR provides an HDMI port which can be connected to an HDMI monitor or TV for doing monitoring in the Full HD (1920 x 1080) resolution.
  • Convenient control of PTZ and speed dome cameras
    The PTZ (Pan/Tilt/Zoom) cameras can be adjusted directly and the preset positions of the IP cameras can be viewed on the local display interface of the VioStor NVR.
  • Digital zoom
    Digital zoom of the video image is supported on the monitoring and playback interfaces of the NVR.
  • On-screen event alert
    When an event occurs, an alert icon will be shown instantly on the local monitoring page. The alert details can be viewed by clicking the alert icon
  • Video search
    The VioStor NVR supports convenient video search by date and time on the local playback interface.
  • Local video playbacks on HDMI monitors or TVs
    The VioStor NVR supports direct video playbacks on HDMI monitors or TVs.
  • Smart control of PTZ & speed dome cameras
    The PTZ (Pan/Tilt/Zoom) cameras can be directly adjusted by the web user interface of the VioStor NVR.
  • Preset position control and auto cruising
    The preset positions of an IP camera can be viewed by clicking the corresponding number buttons on the monitoring page. The time interval can also be configured on the PTZ cameras to perform periodic monitoring.
  • Instant event notification
    When the alarm recording is enabled and an event occurs, an alarm icon will be shown instantly on the monitoring page. The alert details can be viewed by clicking the icon.
  • Dynamic E-map
    The VioStor NVR provides the E-map function for users to upload the digital maps and indicate the locations of the IP cameras of a monitoring location or region.
  • Scheduled remote replication
    The VioStor NVR supports scheduled remote replication for performing secure data backup to a remote QNAP NAS on the local network.
  • One touch auto video backup
    Configure the one touch auto video backup button at the front of the NVR to copy the data from the NVR to an external storage device when the button is pressed.
  • Intel CPU and DDRIII memory for superior system performance
    Powered by the Intel CPU and DDRIII memory, the VioStor NVR delivers superior performance for surveillance applications.
  • CPU thermal solution with fan-less design
    Fan-less design provides better performance, quiet operation, lower energy costs, and enhanced reliability.
  • Touch-N-go PC-less installation
    Complete the first-time system installation, including hard disk initialization and RAID configuration, of the NVR by the LCD panel without using any PC.
  • Detailed event logs
    The VioStor NVR provides detailed event logs of system warnings, hard disk errors, network disconnections, UPS status, and access to the networking services of the NVR and video recordings.
  • S.M.A.R.T. & advanced HDD Health Scanning (HHS)
    S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) helps monitor the hard disk drives status. The VioStor NVR supports HHS for doing disk checking and bad blocks scanning.
QNAP VioStor VS-4116 Pro+ NVR - standalone NVR - 16 channels
NVR - 16 channels - networked
IP Cameras Supported
16
Frame Rate
30 fps
Compression Format
MJPEG, MPEG-4, H.264
Hard Drive(s) Supported
Quantity: 4
Voltage
100 - 240 V
18 cm x 23.5 cm x 18.5 cm
4.6 kg
Country Kits
United Kingdom
NVR
Video Channels
16
16
Compression Format
Package Content
Manual, DVR, software, cables, mounting kit, DVR key
Network cable - RJ-45 - RJ-45 - 2 pcs.
Software Included (Y)
QNAP Finder, Drivers & Utilities
Country Kits
United Kingdom
VCCI, BSMI, FCC
Security DVR
Frame Rate (Record)
30 fps
Display Modes
6 split screens, 9 split screens, 8 split screens, 16 split screens, 4 split screens, 10 split screens, 12 split screens
Playback Search
Date / time, event
Record Events
Alarm, scheduled, manual
Networked
RAID 5 support, RAID 0 support, RAID 1 support, JBOD support, RAID 5 hot spare support, RAID 6 support, watermark, Pan/Tilt/Zoom support, motion detection, key lock, security lock slot (cable lock sold separately), built-in LCD panel
Hard Drive
Quantity Supported
4
Serial ATA
Removable
DDNS Support
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UPnP, SMB, CIFS
Load balancing
Video Output Ports
HDMI x 1
Network Port
10/100/1000Base-T x 2
Other Ports
USB 2.0 x 5, USB 3.0 x 2
Voltage
100 - 240 V
Frequency
50/60 Hz
18 cm
23.5 cm
18.5 cm
4.6 kg
5 - 95% (non-condensing)
