Powered by the Intel dual-core processor and large capacity memory, it delivers high performance at a throughput rate of 250 Mbps to ensure stable recordings and smooth playbacks of multiple megapixel cameras. The 4-bay rackmount VS-4112U-RP Pro+ is designed for the SMB segment with the features of robust performance, solid reliability and high-definition local display.
The VS-4112U-RP Pro+ can support large storage capacity, with hard drive respectively, to accommodate high quality H.264, MPEG-4, M-JPEG, and MxPEG recording videos. The VS-4112U-RP Pro+ supports local display via an HDMI cable, with up to 180 fps Full HD 1080p local display by hardware decoding.
Megapixel recordings
The VioStor NVR supports megapixel recordings (up to 10-megapixel) from various IP cameras. -
Multi-stream support
Administrators now can flexibly define multiple video streams according to bandwidth resources and number of live-view channels. The adjustable video stream setting helps improve the displaying quality of live-view and well manage the bandwidth resources based on different usage requirements. -
Smart recording
The VioStor NVR automatically selects video streams from IP cameras for different recording scenarios. In normal situation, video recording maintains at lower quality resolution. While the alarm event happens, video recording switches to high quality resolution to capture more details. In other words, smart recording effectively avoids the constant storage consumption at all time, but achieves greater storage efficiency and boost recording quality when alarm events happen. -
Real-time digital watermarking
The VioStor NVR supports real-time digital watermarking to protect the videos and snapshots from unauthorized modifications. The watermark proof utility is provided to verify whether or not the videos and snapshots are original. -
High resolution local display
The VioStor NVR provides an HDMI port which can be connected to an HDMI monitor or TV for doing monitoring in the full HD (1920 x 1080) resolution. -
Convenient control of PTZ and speed dome cameras
The PTZ (Pan/Tilt/Zoom) cameras can be adjusted directly and the preset positions of the IP cameras can be viewed on the local display interface of the VioStor NVR. -
Digital zoom
Digital zoom (in/out) of the video image is supported on the monitoring and playback interfaces of the NVR. -
On-screen event alert
When an event occurs, an alert icon will be shown instantly on the local monitoring page. The alert details can be viewed by clicking the alert icon -
Video search
The VioStor NVR supports convenient video search by date and time on the local playback interface. -
Local video playbacks on HDMI monitors or TVs
The VioStor NVR supports direct video playbacks on HDMI monitors or TVs. -
Quick system setup
The VioStor NVR can be set up in simple steps on the local display interface. -
Cross-browser compatibility
On the Windows PC, you can also use Google Chrome, Microsoft Internet Explorer, or Mozilla Firefox to enjoy our surveillance features. -
Smart control of PTZ and speed dome cameras
The PTZ (Pan/Tilt/Zoom) cameras can be directly adjusted by the web user interface of the VioStor NVR. -
Preset position control and auto cruising
The preset positions of an IP camera can be viewed by clicking the corresponding number buttons on the monitoring page. The time interval can also be configured on the PTZ cameras to perform periodic monitoring. -
Instant event notification
When the alarm recording is enabled and an event occurs, an alarm icon will be shown instantly on the monitoring page. The alert details can be viewed by clicking the icon. -
Digital zoom
Digital zoom (in/out) of the video image is supported on the monitoring and playback interfaces. -
Dynamic E-map
The VioStor NVR provides the E-map function for users to upload the digital maps and indicate the locations of the IP cameras of a monitoring location or region. -
Multi-view playback
Use the multi-view playback feature to divide a video equally into multiple sessions for doing playback in a multi-view window, or play the videos of multiple IP cameras in the multi-view window simultaneously. -
Video search by date and time, timeline, event, intelligent video analytics
The VioStor NVR supports quick video search by date and time, timeline, event, and intelligent video analytics (IVA), which includes motion detection, foreign object, missing object, out of focus, and camera occlusion. -
Storage expansion
VioStor NVR provides surveillance storage expansion solution which enables users to leverage the Turbo NAS storage capacity. By installing the StorageExpansion QPKG in the Turbo NAS, administrators can connect the VioStor NVR with the Turbo NAS to flexibly enlarge the total surveillance storage. -
Scheduled remote replication
The VioStor NVR supports scheduled remote replication for performing secure data backup to a remote QNAP NAS on the local network. -
Intel CPU and DDRIII memory for superior system performance
Powered by the Intel CPU and DDRIII memory, the VioStor NVR delivers superior performance for surveillance applications. -
Linux embedded system
The Linux-based VioStor NVR is more power-saving and less vulnerable to virus attacks compared to the PC-based surveillance solution. -
Huge storage capacity for long-term recordings
The VioStor NVR supports large physical storage capacity for recording a large amount of video data over a long period of time. -
Fisheye dewarping
The fisheye dewarping function, available on the web and local display interface for specific fisheye cameras and specific cameras with panomorph lens, assists in doing practical surveillance management, allowing the administrators to view the monitoring area in a clearer shape. -
Authority management
Create multiple users on the VioStor NVR and assign them to different user groups (administrator, system manager, or user) with different rights for doing monitoring, playback, PTZ control, and audio monitoring. -
Auto logoff
The VioStor NVR supports automatic user logoff from idling configuration pages. The administrator can set the timeout period to log off the users when the idling time has been reached. -
Host access control
Specify the host or IP connections to be allowed or denied to access the NVR. -
Advanced RAID with hot-swap design
The VioStor NVR supports RAID 0, 1, 5, 6, 5+hot spare, single, 6+hot spare and JBOD disk configurations. Its hot-swap design allows a failed drive of a disk volume to be replaced by hot swapping without turning off the server. -
S.M.A.R.T. and advanced HDD Health Scanning (HHS)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) helps monitor the hard disk drives status. The VioStor NVR supports HHS (HDD Health Scan) for doing disk checking and bad blocks scanning. -
Automatic system startup after power recovery
The VioStor NVR supports automatic system startup after a power recovery. -
System setup in simple steps
The NVR can be set up in 6 simple steps via the local display or web-based interface (Internet Explorer). -
Web-based user interface
All the system configurations, monitoring, and playback features of the NVR can be managed by the web-based interface. -
Smart search of IP cameras for quick settings
QNAP provides an intelligent software utility, finder, to search for IP cameras and configure the system settings on the local network quickly.
- QNAP VioStor VS-4112U-RP Pro+ - standalone NVR - 12 channels
- NVR - 12 channels - networked - rack-mountable - 1U
- IP Cameras Supported
- 12
- Frame Rate
- 30 fps
- Compression Format
- MJPEG, MPEG-4, H.264, MxPEG
- Hard Drive(s) Supported
- Quantity: 4 - total capacity: 16 TB
- Voltage
- 120 / 230 V
- 43.9 cm x 49.9 cm x 4.4 cm
- 11.54 kg
- Country Kits
- Europe
- NVR - rack-mountable - 1U
- Video Channels
- 12
- 12
- Package Content
- Manual, DVR, software, cables, mounting kit
- Cables Included
- Network cable - RJ-45 - RJ-45 - 2 pcs.
- Software Included (Y)
- QNAP Finder
- Country Kits
- Europe
- VCCI, BSMI, FCC
Security DVR
- Frame Rate (Record)
- 30 fps
- Playback Search
- Date / time, event
- Record Events
- Alarm, motion detection, scheduled, event, manual
- Networked
- RAID 5 support, RAID 0 support, RAID 1 support, JBOD support, RAID 5 hot spare support, RAID 6 support, watermark, Pan/Tilt/Zoom support, motion detection, password protection
Hard Drive
- Quantity Supported
- 4
- Interface
- Serial ATA
- Removable
- Supported Max Total Capacity
- 16 TB
- DDNS Support
- Web Server
- Network Interfaces
- Ethernet 10Base-T/100Base-TX/1000Base-T
- Supported Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, HTTPS, UPnP, SMB, CIFS
- Load balancing, manageable, E-mail alert, FTP server, SMS alert, online RAID capacity expansion, online RAID level migration
- Operating Systems
- Windows Vista, Windows 7, Windows 8
- Video Output Ports
- HDMI x 1
- Alarm Ports
- Alarm input x 8, alarm output x 2
- Camera Control Interface (PTZ)
- RS-232/485
- Network Port
- 10/100/1000Base-T x 2
- Other Ports
- USB 2.0 x 3, USB 3.0 x 2
- Voltage
- 120 / 230 V
- Frequency
- 50/60 Hz
- Power Consumption
- 80 Watt
- Redundant Power Supply
- Included
- 43.9 cm
- 49.9 cm
- 4.4 cm
- 11.54 kg
- 0 °C
- 40 °C
- 0 - 95%
