QNAP VS-12148U-RP-Pro+ 48 Channel 12 Bay 2U Rackmount NVR
Quicklinx: B547WS00 Mfr#: VS-12148U-RP-PRO+-UK
The QNAP VS-12148U-RP Pro+ VioStor NVR (Network Video Recorder) is the high-end 2U chassis network surveillance server which supports high quality real-time video/audio monitoring, megapixel recording, and playback of multiple IP cameras. The VioStor VS-12148U-RP Pro+ can simultaneously handle inputs from up to 48-megapixel cameras. Featuring a powerful Quad-core Intel Core i5 processor and DDR3 memory, this enterprise-grade NVR delivers high performance with throughput of 450 Mbps for recording and smooth playback of multiple megapixel cameras. Moreover, the HDMI output and hardware decoder of VS-12148U-RP Pro+ provide the ability to deliver up to 300 fps Full HD local display.
The Linux-based VioStor VS-12148U-RP Pro+ enables quick and easy deployment of multiple NVRs. It is designed with the user in mind, offering simple and intuitive setup in six steps. Coupled with powerful performance and stability, this solution is tailor-made for enterprise surveillance needs.
  • Megapixel recordings
    The VioStor NVR supports megapixel recordings from various IP cameras.
  • Multi-stream support
    Administrators now can flexibly define multiple video streams according to bandwidth resources and number of live-view channels. The adjustable video stream setting helps improve the displaying quality of live-view and well manage the bandwidth resources based on different usage requirements.
  • Smart recording
    The VioStor NVR automatically selects video streams from IP cameras for different recording scenarios. In normal situation, video recording maintains at lower quality resolution. While the alarm event happens, video recording switches to high quality resolution to capture more details. In other words, smart recording effectively avoids the constant storage consumption at all time, but achieves greater storage efficiency and boost recording quality when alarm events happen.
  • Real-time digital watermarking
    The VioStor NVR supports real-time digital watermarking to protect the videos and snapshots from unauthorized modifications. The watermark proof utility is provided to verify whether or not the videos and snapshots are original.
  • High resolution local display
    The VioStor NVR provides an HDMI port which can be connected to an HDMI monitor or TV for doing monitoring in the Full HD (1920 x 1080) resolution.
  • Convenient control of PTZ and speed dome cameras
    The PTZ (Pan/Tilt/Zoom) cameras can be adjusted directly and the preset positions of the IP cameras can be viewed on the local display interface of the VioStor NVR.
  • Video search
    The VioStor NVR supports convenient video search by date and time on the local playback interface.
  • Local video playbacks on HDMI monitors or TVs
    The VioStor NVR supports direct video playbacks on HDMI monitors or TVs.
  • Quick system setup
    The VioStor NVR can be set up in simple steps on the local display interface.
  • Instant event notification
    When the alarm recording is enabled and an event occurs, an alarm icon will be shown instantly on the monitoring page. The alert details can be viewed by clicking the icon.
  • Digital zoom
    Digital zoom (in/out) of the video image is supported on the monitoring and playback interfaces.
  • Dynamic E-map
    The VioStor NVR provides the E-map function for users to upload the digital maps and indicate the locations of the IP cameras of a monitoring location or region.
  • Multi-view playback
    Use the multi-view playback feature to divide a video equally into multiple sessions for doing playback in a multi-view window, or play the videos of multiple IP cameras in the multi-view window simultaneously.
  • Fisheye dewarping
    The fisheye dewarping function, available on the web and local display interface for specific fisheye cameras and specific cameras with panomorph lens, assists in doing practical surveillance management, allowing the administrators to view the monitoring area in a clearer shape.
  • Authority management
    Create multiple users on the VioStor NVR and assign them to different user groups (administrator, system manager, or user) with different rights for doing monitoring, playback, PTZ control, and audio monitoring.
  • Auto logoff
    The VioStor NVR supports automatic user logoff from idling configuration pages. The administrator can set the timeout period to log off the users when the idling time has been reached.
  • Host access control
    Specify the host or IP connections to be allowed or denied to access the NVR.
  • Detailed event logs
    The VioStor NVR provides detailed event logs of system warnings, hard disk errors, network disconnections, UPS status, and access to the networking services of the NVR and video recordings.
  • Web-based user interface
    All the system configurations, monitoring, and playback features of the NVR can be managed by the web-based interface.
  • Smart search of IP cameras for quick settings
    QNAP provides an intelligent software utility, finder, to search for IP cameras and configure the system settings on the local network quickly.
QNAP VioStor VS-12148U-RP Pro+ - standalone NVR - 48 channels
NVR - 48 channels - networked - rack-mountable - 2U
IP Cameras Supported
48
Frame Rate
30 fps
Compression Format
MJPEG, MPEG-4, H.264, MxPEG
Hard Drive(s) Supported
Quantity: 12 - total capacity: 48 TB
Voltage
120 / 230 V
43.9 cm x 52 cm x 8.8 cm
15.88 kg
NVR - rack-mountable - 2U
Video Channels
48
48
Compression Format
Package Content
Manual, DVR, software, cables, mounting kit
Network cable - RJ-45 - RJ-45 - 4 pcs.
Software Included (Y)
QNAP Finder
VCCI, BSMI, FCC, LVD
Security DVR
Frame Rate (Record)
30 fps
Display Modes
6 split screens, 9 split screens, full screen, 8 split screens, 16 split screens, 4 split screens, 10 split screens, 12 split screens
Playback Search
Date / time, event
Record Events
Alarm, motion detection, scheduled, event, manual
Networked
RAID 5 support, RAID 0 support, RAID 1 support, JBOD support, RAID 5 hot spare support, RAID 6 support, RAID 6 hot spare support, watermark, Pan/Tilt/Zoom support, motion detection, password protection, e-mail alarm notifications
Hard Drive
Quantity Supported
12
Serial ATA
Removable
Supported Max Total Capacity
48 TB
DDNS Support
Web Server
Network Interfaces
Ethernet 10Base-T/100Base-TX/1000Base-T
Supported Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UPnP, SMB, CIFS
Load balancing, manageable, E-mail alert, SMS alert, online RAID capacity expansion, online RAID level migration
Video Output Ports
HDMI x 1, VGA x 1
Network Port
10/100/1000Base-T x 4
Other Ports
USB 2.0 x 4, USB 3.0 x 2
Voltage
120 / 230 V
Frequency
50/60 Hz
Power Consumption
167 Watt
Redundant Power Supply
Included
43.9 cm
52 cm
8.8 cm
15.88 kg
0 - 90%
