QNAP UX-800U-RP Expansion Unit
Quicklinx: B8VXWS00 Mfr#: UX-800U-RP
Type: Hard drive array
Controller Type: None
£858.52 ex VAT
£1,030.22 inc VAT
When expanding data storage capacity, deploying multiple servers can lead to complexity in management and also dramatically increase costs. The QNAP UX-800U-RP expansion enclosure is an economical expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS. The UX-800U-RP offers a hassle-free storage expansion for business use. Each UX-800U-RP provides additional 8 hard drives for the Turbo NAS and allows for a total raw capacity making it especially useful for massive data backup, digital media collection, and video surveillance.
Simply connect the UX-800U-RP to a Turbo NAS and power it on. The Turbo NAS will automatically detect the hard drives in the UX-800U-RP as newly installed local drives. The Turbo NAS capacity can then be expanded as a large volume seamlessly & economically by using the powerful QTS Storage Manager.
  • Missing mode protection
    If your UX-800U-RP is accidentally disconnected, the Turbo NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data remaining intact.
  • Powerful QTS Storage Manager
    The QTS Storage Manager neatly presents tools & options for managing system storage with a modern & intuitive graphical user interface, greatly simplifying the process of managing the UX-800U-RP and NAS capacity expansion. You can easily monitor the health status of the UX-800U-RP and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quickly maintaining the UX-800U-RP.
  • Flexible RAID Configuration
    The UX-800U-RP features 8 hot-swap drive bays for easy installation & removal. The automatic insertion/removable detection and rebuild allow easy management. Featuring Supporting RAID 0, 1, 5, 6 and 10 and managed by the powerful QTS Storage Manager, the UX-800U-RP ensures maximum performance and data security.
  • An excellent backup solution for Turbo NAS
    The UX-800U-RP can be used as a cost-efficient external storage to perform fast & secure backup tasks for the Turbo NAS. The administrator can back up the Turbo NAS data to the UX-800U-RP on a real time or scheduled basis.
  • Excellent hardware design
    The UX-800U-RP includes redundant 300W internal PSUs to ensure business continuity and to provide ample power even under a sustained full load. You can replace a failed power supply unit without turning off the server. The well-ventilated chassis and smart fan provides efficient cooling for better stability & reliability, with the easily-replaceable fan module enabling efficient heat removal even when all 8 drives are under full operation simultaneously.
QNAP UX-800U-RP - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
USB 3.0
8 (max)
Supported Drives
SATA-600
Built-in Devices
Status LCD, led panel
Hard Drive
0 - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
Built-in Devices
Supported Devices / Modules Qty
8
Supported Drives
SATA-600
Storage
HDD Array External Interface
USB 3.0
Hard Drive
Hot-swap
0
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B
K-lock security slot, built-in 2 cooling fans
1 x USB 3.0 cable
2 x internal power supply
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
5 °C
35 °C
5 - 95% (non-condensing)
Brand: QNAP
Price Range Ex VAT: 750 - 1000
