Your basket is empty
QNAP UX-800U-RP 48TB (8 x 6TB WD RED PRO HDDs) 8 Bay Rackmount NAS
Quicklinx: BST5WS00 Mfr#: UX-800U-RP/48TB-RED PRO
When expanding data storage capacity, deploying multiple servers can lead to complexity in management and also dramatically increase costs. The QNAP UX-800U-RP expansion enclosure is an economical expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS. The UX-800U-RP offers a hassle-free storage expansion for business use. Each UX-800U-RP provides additional 8 hard drives for the Turbo NAS and allows for a total raw capacity making it especially useful for massive data backup, digital media collection, and video surveillance.
Simply connect the UX-800U-RP to a Turbo NAS and power it on. The Turbo NAS will automatically detect the hard drives in the UX-800U-RP as newly installed local drives. The Turbo NAS capacity can then be expanded as a large volume seamlessly & economically by using the powerful QTS Storage Manager.
QNAP UX-800U-RP - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
48 TB
USB 3.0
8 (installed) / 8 (max)
Supported Drives
SATA-600
Built-in Devices
Status LCD, led panel
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
8 x 6 TB HDD SATA 6Gb/s - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
Built-in Devices
8
Supported Devices / Modules Qty
8
Supported Drives
SATA-600
Storage
48 TB
HDD Array External Interface
USB 3.0
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hard Drive
HDD - hot-swap
8 x 6 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B
Security lock slot (cable lock sold separately), built-in 2 cooling fans
1 x USB 3.0 cable
2 x internal power supply
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
5 °C
35 °C
5 - 95% (non-condensing)
