When expanding data storage capacity, deploying multiple servers can lead to complexity in management and also dramatically increase costs. The QNAP UX-800U-RP expansion enclosure is an economical expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS. The UX-800U-RP offers a hassle-free storage expansion for business use. Each UX-800U-RP provides additional 8 hard drives for the Turbo NAS and allows for a total raw capacity of 64TB making it especially useful for massive data backup, digital media collection, and video surveillance.
Easily add additional drive capacity to a Turbo NAS
Simply connect the UX-800U-RP to a Turbo NAS and power it on. The Turbo NAS will automatically detect the hard drives in the UX-800U-RP as newly installed local drives. The Turbo NAS capacity can then be expanded as a large volume seamlessly & economically by using the powerful QTS Storage Manager. -
Missing mode protection
If your UX-800U-RP is accidentally disconnected, the Turbo NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data remaining intact. -
Powerful QTS Storage Manager
The QTS Storage Manager neatly presents tools & options for managing system storage with a modern & intuitive graphical user interface, greatly simplifying the process of managing the UX-800U-RP and NAS capacity expansion. You can easily monitor the health status of the UX-800U-RP and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quickly maintaining the UX-800U-RP. -
Flexible RAID Configuration
The UX-800U-RP features 8 hot-swap drive bays for easy installation & removal. The automatic insertion/removable detection and rebuild allow easy management. Featuring Supporting RAID 0, 1, 5, 6 and 10 and managed by the powerful QTS Storage Manager, the UX-800U-RP ensures maximum performance and data security. -
An excellent backup solution for Turbo NAS
The UX-800U-RP can be used as a cost-efficient external storage to perform fast & secure backup tasks for the Turbo NAS. The administrator can back up the Turbo NAS data to the UX-800U-RP on a real time or scheduled basis. -
Excellent hardware design
The UX-800U-RP includes redundant 300W internal PSUs to ensure business continuity and to provide ample power even under a sustained full load. You can replace a failed power supply unit without turning off the server. The well-ventilated chassis and smart fan provides efficient cooling for better stability & reliability, with the easily-replaceable fan module enabling efficient heat removal even when all 8 drives are under full operation simultaneously.
- QNAP - hard drive array
- Hard drive array
- Enclosure Type
- Rack-mountable - 2U
- Total Array Capacity
- 24 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 8 (installed) / 8 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Status LCD, led panel
- Hard Drive
- 8 x 3 TB HDD SATA 6Gb/s - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Power Redundancy
- Hard drive array
- Enclosure Type
Chassis
- Built-in Devices
- 8
- Supported Devices / Modules Qty
- 8
- Supported Drives
- SATA-600
Storage
- 24 TB
- HDD Array External Interface
- USB 3.0
- CPU
- No CPU
Hard Drive
- HDD - hot-swap
- Capacity
- 8 x 3 TB
- Interface Type
- SATA 6Gb/s
- Expansion Bays
- 8 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 1 x USB 3.0 - 9 pin USB Type B
- K-lock security slot, built-in 2 cooling fans
- Cables Included
- 1 x USB 3.0 cable
- Power Device
- 2 x internal power supply
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- 5 °C
- 35 °C
- 5 - 95% (non-condensing)
