Product
QNAP UX-800P 8TB (8x1TB WD RED) Expansion Unit
Quicklinx: 9QZMWS00 Mfr#: UX-800P/8TB-RED
When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased cost. The QNAP UX-800P expansion enclosure is a budget-friendly expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS for general applications. By connecting one expansion enclosure, the UX-800P offers a hassle-free storage expansion for home/small office use.
  • Easily add additional drive capacity to a Turbo NAS
    Simply connect the UX-800P to a Turbo NAS and power it on. The Turbo NAS will automatically detect the hard drives in the UX-800P as newly installed local drives. The Turbo NAS capacity can then be expanded as a large volume seamlessly and economically by using the powerful QTS Storage Manager.
  • Missing mode protection
    If your UX-800P is accidentally disconnected, the Turbo NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact.
  • Powerful QTS storage manager
    The QTS storage manager neatly presents tools and options for managing system storage with a modern & intuitive graphical user interface, which greatly simplifies the process of NAS capacity expansion and UX-800P management. No matter if you are an IT administrator or Home user, you can easily monitor the health status of UX-800P and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quick maintenance.
  • Flexible RAID Configuration
    The UX-800P features 8 hot-swap drive bays for easy installation and removal. The automatic insertion/removable detection and rebuild allow easy management. Featuring RAID 0, 1, 5, 6 and 10 supports and managed by the powerful QTS storage manager, the UX-800P ensures maximum performance and data security.
  • An excellent backup solution for Turbo NAS
    The UX-800P can be used as a budget-friendly external storage to perform speedy and secure backup tasks for the Turbo NAS. The administrator can back up the Turbo NAS data to the UX-800P on a real time or scheduled basis.
  • Smart power design
    The UX-800P automatically powers on and off with your Turbo NAS, allowing for total convenience and energy saving.
  • Excellent hardware design
    The UX-800P includes a full 350W internal PSU to provide ample power even under sustained full load. The well-ventilated chassis and smart fan helps to provide efficient cooling for better stability and reliability, with the fan enabling efficient heat removal even when all 8 drives are under full operation simultaneously.
QNAP UX-800P - hard drive array
Hard drive array
Total Array Capacity
8 TB
USB 3.0
8 (installed) / 8 (max)
Supported Drives
SATA-600
Built-in Devices
Status LCD, led panel
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
8 x 1 TB HDD SATA 6Gb/s - hot-swap
AC 120/230 V - 50/60 Hz
Hard drive array
Chassis
Built-in Devices
8
Supported Devices / Modules Qty
8
Supported Drives
SATA-600
Storage
8 TB
HDD Array External Interface
USB 3.0
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hard Drive
HDD - hot-swap
8 x 1 TB
Interface Type
SATA 6Gb/s
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B
Security lock slot (cable lock sold separately), built-in 2 cooling fans
1 x USB 3.0 cable
Internal power supply
Power Provided
350 Watt
5 °C
35 °C
5 - 95% (non-condensing)
