When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased cost. The QNAP UX-500P expansion enclosure is a budget-friendly expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS for general applications. By connecting one expansion enclosure, the UX-500P offers a hassle-free storage expansion for home/small office use.
Easily add additional drive capacity to a Turbo NAS
Simply connect the UX-500P to a Turbo NAS and power it on. The Turbo NAS will automatically detect the hard drives in the UX-500P as newly installed local drives. The Turbo NAS capacity can then be expanded as a large volume seamlessly and economically by using the powerful QTS storage manager. -
Missing mode protection
If your UX-500P is accidentally disconnected, the Turbo NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact. -
Powerful QTS storage manager
The QTS storage manager neatly presents tools and options for managing system storage with a modern & intuitive graphical user interface, which greatly simplifies the process of NAS capacity expansion and UX-500P management. No matter if you are an IT administrator or Home user, you can easily monitor the health status of UX-500P and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quick maintenance. -
Flexible RAID configuration
The UX-500P features 5 hot-swap drive bays for easy installation and removal. The automatic insertion/removable detection and rebuild allow easy management. Featuring RAID 0, 1, 5, 6 and 10 support and managed by the powerful QTS storage manager, the UX-500P ensures maximum performance and data security. -
An excellent backup solution for Turbo NAS
The UX-500P can be used as a budget-friendly external storage to perform speedy and secure backup tasks for the Turbo NAS. The administrator can back up the Turbo NAS data to the UX-500P on a real time or scheduled basis. -
Smart power design
The UX-500P automatically powers on and off with your Turbo NAS, allowing for total convenience and energy saving. -
Excellent hardware design
The UX-500P includes a full 250W internal PSU to provide ample power even under sustained full load. The well-ventilated chassis and smart fan helps to provide efficient cooling for better stability and reliability, with the fan enabling efficient heat removal even when all 5 drives are under full operation simultaneously.
- QNAP UX-500P - storage enclosure
- Storage enclosure
- Installed Devices / Modules Qty
- 0 (installed) / 5 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Status LCD
- Hard Drive
- No HDD
- Power
- AC 120/230 V - 50/60 Hz
- Designed For
- QNAP HS-251 Turbo NAS, TS-253 Pro, TS-453 Pro, TS-453S Pro Turbo NAS, TS-653 Pro, TS-853 Pro Turbo NAS, TS-853S Pro
- Storage enclosure
Chassis
- Built-in Devices
- Status LCD
- 0
- Supported Devices / Modules Qty
- 5
- Supported Drives
- SATA-600
- CPU
- No CPU
Hard Drive
- No HDD
- Expansion Bays
- 5 (total) / 5 (free) x hot-swap - 2.5" / 3.5" shared
- 1 x USB 3.0 - 9 pin USB Type B
- Security lock slot (cable lock sold separately), built-in cooling fan
- Cables Included
- 1 x USB 3.0 cable
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- 5 °C
- 35 °C
- 5 - 95% (non-condensing)
- Designed For
