When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased cost. The QNAP UX-500P expansion enclosure is a budget-friendly expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS for general applications. By connecting one expansion enclosure, the UX-500P offers a hassle-free storage expansion for home/small office use.
- QNAP UX-500P - hard drive array
- Hard drive array
- Total Array Capacity
- 20 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 5 (installed) / 5 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Status LCD, led panel
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- 5 x 4 TB HDD SATA 6Gb/s - hot-swap
- Power
- AC 120/230 V - 50/60 Hz
- Hard drive array
Chassis
- Built-in Devices
- 5
- Supported Devices / Modules Qty
- 5
- Supported Drives
- SATA-600
Storage
- 20 TB
- HDD Array External Interface
- USB 3.0
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
Hard Drive
- HDD - hot-swap
- Capacity
- 5 x 4 TB
- Interface Type
- SATA 6Gb/s
- Expansion Bays
- 5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 1 x USB 3.0 - 9 pin USB Type B
- Security lock slot (cable lock sold separately), built-in cooling fan
- Cables Included
- 1 x USB 3.0 cable
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- 5 °C
- 35 °C
- 5 - 95% (non-condensing)
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.00 | in stock |
£887.01
saving £2.50
saving £2.50
