Product
QNAP UX-1200U-RP Expansion Unit
Quicklinx: B8VWWS00 Mfr#: UX-1200U-RP
Type: Hard drive array
Controller Type: None
Hurry, only 2 left in stock!
£1,005.07 ex VAT
£1,206.08 inc VAT
Flexible storage scalability for your Turbo NAS. Quick & simple.
When expanding data storage capacity, deploying multiple servers can lead to complexity in management and also dramatically increase costs. The QNAP UX-1200U-RP expansion enclosure is an economical expansion alternative designed with easy setup in mind for expanding the total storage space of your Turbo NAS. The UX-1200U-RP offers a hassle-free storage expansion for business use. Each UX-1200U-RP provides additional 12 hard drives for the Turbo NAS and allows for a total raw capacity of 96 TB* making it especially useful for massive data backup, digital media collection, and video surveillance.
Easily add additional drive capacity to a Turbo NAS
Simply connect the UX-1200U-RP to a Turbo NAS* and power it on. The Turbo NAS will automatically detect the hard drives in the UX-1200U-RP as newly installed local drives. The Turbo NAS capacity can then be expanded as a large volume seamlessly & economically by using the powerful QTS Storage Manager.
*QTS 4.0.5 or newer is required for the Turbo NAS.
Missing mode protection
If your UX-1200U-RP is accidentally disconnected, the Turbo NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data remaining intact.
Powerful QTS Storage Manager
The QTS Storage Manager neatly presents tools & options for managing system storage with a modern & intuitive graphical user interface, greatly simplifying the process of managing the UX-1200U-RP and NAS capacity expansion. You can easily monitor the health status of the UX-1200U-RP and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quickly maintaining the UX-1200U-RP.
Flexible RAID Configuration
The UX-1200U-RP features 12 hot-swap drive bays for easy installation & removal. The automatic insertion/removable detection and rebuild allow easy management. Featuring Supporting RAID 0, 1, 5, 6 and 10 and managed by the powerful QTS Storage Manager, the UX-1200U-RP ensures maximum performance and data security.
An excellent backup solution for Turbo NAS
The UX-1200U-RP can be used as a cost-efficient external storage to perform fast & secure backup tasks for the Turbo NAS. The administrator can back up the Turbo NAS data to the UX-1200U-RP on a real time or scheduled basis.
Excellent hardware design
The UX-1200U-RP includes redundant 300W internal PSUs to ensure business continuity and to provide ample power even under a sustained full load. You can replace a failed power supply unit without turning off the server. The well-ventilated chassis and smart fan provides efficient cooling for better stability & reliability, with the easily-replaceable fan module enabling efficient heat removal even when all 12 drives are under full operation simultaneously.
QNAP UX-1200U-RP - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
USB 3.0
12 (max)
Supported Drives
SATA-600
Built-in Devices
Status LCD, led panel
Hard Drive
0 - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
Built-in Devices
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Storage
HDD Array External Interface
USB 3.0
Hard Drive
Hot-swap
0
Expansion Bays
12 (total) / 12 (free) x hot-swap - 2.5" / 3.5" shared
1 x USB 3.0 - 9 pin USB Type B
K-lock security slot, built-in 2 cooling fans
1 x USB 3.0 cable
2 x internal power supply
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
5 °C
35 °C
5 - 95% (non-condensing)
Brand: QNAP
Price Range Ex VAT: 1000 - 1500
