When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased costs. QNAP TX-800P expansion enclosure provides a flexible expansion alternative designed with easy setup in mind for scaling up Thunderbolt NAS storage space via high-speed Thunderbolt 2 (20Gbps) cables. The TX-800P provides an additional 8 hard drives providing up to 64 TB expanded capacity for the Thunderbolt NAS, making it ideal for data backup, 4K digital media collection and video surveillance storage with blazing-fast data transmission performance.
Easily add additional drive capacity to a Thunderbolt NAS
Simply connect the TX-800P to a Thunderbolt NAS via Thunderbolt 2 cables and power it on. The Thunderbolt NAS will automatically detect the hard drives in the TX-800P as newly-installed local drives. The Thunderbolt NAS capacity can then be seamlessly expanded as a large volume by using the powerful QTS Storage Manager. -
Missing mode protection
If your TX-800P is accidentally disconnected, the Thunderbolt NAS enters missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact. -
Powerful QTS Storage Manager
The QTS Storage Manager neatly presents tools and options for managing system storage with a modern & intuitive graphical user interface, which greatly simplifies the process of NAS capacity expansion and TX-800P management. IT administrators can easily monitor the health status of TX-800P and the disks within it. When multiple expansion enclosures are connected, the Locate Disk and Locate Enclosure functions assist you in quick maintenance. -
Efficient backup solution for Thunderbolt NAS
In addition to expanding an existing volume, you can use the TX-800P as a flexible external storage to perform speedy and secure backup tasks for the Thunderbolt NAS. The QNAP RTRR (Real-Time Remote Replication) or rsync service lets IT administrators back up Thunderbolt NAS data to the TX-800P on a real time or scheduled basis. -
Smart power design
The TX-800P automatically powers on and off with your Thunderbolt NAS, allowing for total convenience and energy saving. -
Flexible drive selection
The TX-800P offers high flexibility in hard drive selection. IT administrators can choose low-cost but high-capacity SATA HDDs for large data archiving, or high-speed and high-stability SSDs for I/O intensive operations. -
Excellent hardware design
The TX-800P includes a full 350W internal PSU to provide ample power even under sustained full load. The well-ventilated chassis and smart fan helps to provide efficient cooling for better stability and reliability, with the fan enabling efficient heat removal even when all 8 drives are under full operation simultaneously.
- QNAP TX-800P - hard drive array
- Hard drive array
- Interface
- Thunderbolt 2
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Status LCD
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Power
- AC 120/230 V - 50/60 Hz
- 29.82 cm x 23.54 cm x 18.52 cm
- 7.3 kg
- Hard drive array
Chassis
- Built-in Devices
- Status LCD
- 0
- Supported Devices / Modules Qty
- 8
- Supported Drives
- SATA-600
Storage
- HDD Array External Interface
- Thunderbolt 2
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
Hard Drive
- No HDD
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" shared
- 2 x Thunderbolt 2
- Security lock slot (cable lock sold separately), built-in 2 cooling fans
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- 29.82 cm
- 23.54 cm
- 18.52 cm
- 7.3 kg
- 5 °C
- 35 °C
- 5 - 95% (non-condensing)
