QNAP TVS-882ST series is a compact storage solution equipped with Thunderbolt and 10GbE technologies. It has three modes (Thunderbolt/NAS/iSCSI SAN) and is presented in a compact design. With its Thunderbolt technology and the included dual 10 Gigabit Ethernet (10GbE), TVS-882ST gives you the ultimate flexibility. Designed for Mac and Windows PC with Thunderbolt technology, TVS-882ST series is the ultimate storage solution for 4K audio and video post-production process or 10GbE file storage and backup.
- QNAP TVS-882ST3 - NAS server
- NAS server
- Host Connectivity
- 10 Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 18 cm x 23.5 cm x 17.7 cm
- 3.97 kg ()
- Processor
- 1 x Intel Core i7 6700HQ 2.6 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.3
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
- NAS server
- Host Connectivity
- Total Storage Capacity
- 0 GB
- 18 cm
- 23.5 cm
- 17.7 cm
- 3.97 kg ()
- Built-in Devices
- Status LCD, led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 3.5 GHz
- RAM
- 16 GB (installed) / 32 GB (supported) - DDR4
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, DHCP, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, download client, file sharing, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, audible alarm notification, e-mail notification, WebDAV server, 4K resolution support, cloud backup, VPN Server, Apple AirPlay, 720p resolution support, Dropbox support, Real-time Remote Replication (RTRR), QvPC Technology, Google Drive support, 1080p resolution support, failover protection, built-in smart alarm, VPN client, Amazon Cloud Drive support, Microsoft OneDrive support, OpenStack compatible
- Encryption Algorithm
- SSL, 256-bit AES, AES-NI
- UPnP
- Expansion Bays
- 6 (total) / 6 (free) x hot-swap - 2.5"
- Expansion Slots
- 1 (total) / 0 (free) x PCI Express 3.0 x8 , 1 (total) / 0 (free) x PCI Express 3.0 x4 , 2 (total) / 0 (free) x SO-DIMM 260-pin
- 2 x Ethernet 1000Base-T - RJ-45 , 1 x HDMI output , 2 x USB 3.0 - Type A , 1 x audio out - mini-jack , 2 x Thunderbolt 3 , 2 x Ethernet 10Gb , 1 x USB 3.1 - Type C , 1 x USB 3.1 - Type A , 1 x microphone - mini-jack
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), audible alarm, built-in cooling fan
- FIPS 140-2
- Included Accessories
- Remote control
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 240 Watt
- QNAP QTS 4.3
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
