The TVS-882BRT3 uses advanced processors and features Thunderbolt 3 (40 Gbps) connectivity, including a unique Thunderbolt-to-Ethernet (T2E) 10 GbE converter, and is ideal for online video editing and high-speed file sharing. The TVS-882BRT3 comes with an optical disc drive (ODD) slot, allowing you to install compatible disc drives (including Blu-ray Disc drives).
Easy installation, quick backup and sharing
The TVS-882BRT3 comes with a SATA optical disc drive (ODD) expansion slot allowing you to install a 5.25" disc burner or two Slim SATA disc burners. The TVS-882BRT3 also supports USB disc drives. QNAP provides models with preloaded Blu-ray ODD for you to enjoy disc-related applications instantly. After installing the ODD, you can browse disc files directly through File Station and quickly backup the files to NAS, saving you time and trouble from transferring files to computer first then to the NAS. -
Complete data backup with DVDFab
DVDFab provides a convenient solution for users who need an all-in-one and user-friendly solution for optical disc backup and authoring. Users can easily archive the content of discs to their NAS and write NAS-based data to disc using DVDFab on their TVS-882BRT3 without needing a separate computer. -
Thunderbolt 3 NAS, extraordinary performance
Powered by advanced processors, DDR4 2133 MHz RAM, four Gigabit Ethernet ports, and SATA 6 Gb/s interface, the TVS-882BRT3 provides high read/ write speeds. The TVS-882BRT3 features Intel AES-NI-accelerated encryption for both full NAS volumes and shared folders, boosting system performance and security while ensuring the safety of sensitive data stored in the TVS-882BRT3. The Thunderbolt 3 ports provide up to 40 Gbps bandwidth for high-speed data transfer. Users can also utilize its Thunderbolt 3 ports to have USB-C 3.1 Gen2 (10 Gbps) connectivity for quickly transferring and backing up large-sized media files from USB-C devices.
- QNAP TVS-882BRT3 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 36.99 cm x 31.98 cm x 23.46 cm
- 12.18 kg ()
- Processor
- 1 x Intel Core i7 7700 3.6 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Optical Storage
- 1 x BD-Writer
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 32 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.2
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 36.99 cm
- 31.98 cm
- 23.46 cm
- 12.18 kg ()
- Built-in Devices
- Status LCD, led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 4.2 GHz
- RAM
- 32 GB (installed) / 64 GB (supported) - DDR4
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Optical Storage
- 1 x BD-Writer - 5.25"
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- 256-bit AES
- UPnP
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" , 1 (total) / 0 (free) x external - 5.25"
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express 3.0 x8 , 2 (total) / 2 (free) x PCI Express 3.0 x4 , 2 (total) / 2 (free) x M.2 , 4 (total) / 2 (free) x DIMM 288-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 3 x HDMI output , 5 x USB 3.0 - Type A , 2 x audio in - 6.3mm jack , 1 x audio out - mini-jack , 4 x Thunderbolt 3
- Cables Included
- 4 x network cable
- Audible alarm
- FIPS 140-2
- Included Accessories
- Remote control
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- QNAP QTS 4.2
- OS Required
