Product
Brand
QNAP TVS-882BRT3-ODD-i7-32G 8 Bay NAS Desktop
Quicklinx: D898WS00 Mfr#: TVS-882BRT3-ODD-i7-32G
Capacity: 0GB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • BD-Writer
  • Core i7
£2,916.39 ex VAT
£3,499.66 inc VAT
The TVS-882BRT3 uses advanced processors and features Thunderbolt 3 (40 Gbps) connectivity, including a unique Thunderbolt-to-Ethernet (T2E) 10 GbE converter, and is ideal for online video editing and high-speed file sharing. The TVS-882BRT3 comes with an optical disc drive (ODD) slot, allowing you to install compatible disc drives (including Blu-ray Disc drives).
QNAP TVS-882BRT3 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 8 (max)
36.99 cm x 31.98 cm x 23.46 cm
12.18 kg
1 x Intel Core i7 7700 3.6 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Optical Storage
1 x BD-Writer
10Mb LAN, 100Mb LAN, GigE
RAM
32 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
36.99 cm
31.98 cm
23.46 cm
12.18 kg
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
4.2 GHz
RAM
32 GB (installed) / 64 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Optical Storage
1 x BD-Writer - 5.25"
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
256-bit AES
UPnP
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" , 1 (total) / 0 (free) x external - 5.25"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 2 (total) / 2 (free) x PCI Express 3.0 x4 , 2 (total) / 2 (free) x M.2 , 4 (total) / 2 (free) x DIMM 288-pin
4 x Ethernet 1000Base-T - RJ-45 , 3 x HDMI output , 5 x USB 3.0 - Type A , 2 x audio in - 6.3mm jack , 1 x audio out - mini-jack , 4 x Thunderbolt 3
4 x network cable
Audible alarm
FIPS 140-2
Remote control
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.2
Capacity: 0GB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: QNAP
Price Range Ex VAT: 1500+
