Product
QNAP TVS-882BRT3-ODD-i5-16G 8 Bay NAS Desktop
Quicklinx: D897WS00 Mfr#: TVS-882BRT3-ODD-i5-16G
Capacity: 0GB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • BD-Writer
  • Core i5
£2,420.91 ex VAT
£2,905.09 inc VAT
The TVS-882BRT3 uses advanced processors and features Thunderbolt 3 (40 Gbps) connectivity, including a unique Thunderbolt-to-Ethernet (T2E) 10 GbE converter, and is ideal for online video editing and high-speed file sharing. The TVS-882BRT3 comes with an optical disc drive (ODD) slot, allowing you to install compatible disc drives (including Blu-ray Disc drives).
  • Easy installation, quick backup and sharing
    The TVS-882BRT3 comes with a SATA optical disc drive (ODD) expansion slot allowing you to install a 5.25" disc burner or two Slim SATA disc burners. The TVS-882BRT3 also supports USB disc drives. QNAP provides models with preloaded Blu-ray ODD for you to enjoy disc-related applications instantly. After installing the ODD, you can browse disc files directly through File Station and quickly backup the files to NAS, saving you time and trouble from transferring files to computer first then to the NAS.
  • Complete data backup with DVDFab
    DVDFab provides a convenient solution for users who need an all-in-one and user-friendly solution for optical disc backup and authoring. Users can easily archive the content of discs to their NAS and write NAS-based data to disc using DVDFab on their TVS-882BRT3 without needing a separate computer.
  • Thunderbolt 3 NAS, extraordinary performance
    Powered by advanced processors, DDR4 2133 MHz RAM, four Gigabit Ethernet ports, and SATA 6 Gb/s interface, the TVS-882BRT3 provides high read/ write speeds. The TVS-882BRT3 features Intel AES-NI-accelerated encryption for both full NAS volumes and shared folders, boosting system performance and security while ensuring the safety of sensitive data stored in the TVS-882BRT3. The Thunderbolt 3 ports provide up to 40 Gbps bandwidth for high-speed data transfer. Users can also utilize its Thunderbolt 3 ports to have USB-C 3.1 Gen2 (10 Gbps) connectivity for quickly transferring and backing up large-sized media files from USB-C devices.
QNAP TVS-882BRT3 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
0 (installed) / 8 (max)
36.99 cm x 31.98 cm x 23.46 cm
12.18 kg
1 x Intel Core i5 7500 3.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Optical Storage
1 x BD-Writer
10Mb LAN, 100Mb LAN, GigE
RAM
16 GB
Storage Operating System
QNAP QTS 4.2
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
36.99 cm
31.98 cm
23.46 cm
12.18 kg
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
Max Turbo Speed
3.8 GHz
RAM
16 GB (installed) / 64 GB (supported) - DDR4
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Optical Storage
1 x BD-Writer - 5.25"
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
256-bit AES
UPnP
Expansion Bays
8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express 3.0 x8 , 2 (total) / 2 (free) x PCI Express 3.0 x4 , 2 (total) / 2 (free) x M.2 , 4 (total) / 2 (free) x DIMM 288-pin
4 x Ethernet 1000Base-T - RJ-45 , 3 x HDMI output , 5 x USB 3.0 - Type A , 2 x audio in - 6.3mm jack , 1 x audio out - mini-jack , 4 x Thunderbolt 3
4 x network cable
Audible alarm
FIPS 140-2
Remote control
Internal power supply
Power Provided
250 Watt
QNAP QTS 4.2
Capacity: 0GB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Brand: QNAP
Price Range Ex VAT: 1500+
