The TVS-882BR uses advanced processors, providing advanced hardware with enhanced tiring storage, application-based partitioning and network traffic distribution. The TVS-882BR comes with a SATA optical disc drive (ODD) slot, allowing you to install a compatible Blu-ray Disc drive. QNAP also provides models with a preloaded ODD, allowing you to experience extensive disc applications right way. With simple installation, you can backup the content of your discs to NAS for long-term storage and easier sharing, or you can burn NAS files to disc.
Easy installation, quick backup and sharing
The TVS-882BR comes with a SATA optical disc drive (ODD) expansion slot allowing you to install a 5.25" disc burner or two Slim SATA disc burners. The TVS-882BR also supports USB disc drives. QNAP provides models with preloaded Blu-ray ODD for you to enjoy disc-related applications instantly. After installing the ODD, you can browse disc files directly through File Station and quickly backup the files to NAS, saving you time and trouble from transferring files to computer first then to the NAS. Multiple sharing modes (email, social network, sharing link, share to other NAS users) allows you to easily share information to others, solving the inconvenience of sharing disc files before. -
Complete data backup with DVDFab
DVDFab provides a convenient solution for users who need an all-in-one and user-friendly solution for optical disc backup and authoring. Users can easily archive the content of discs to their NAS and write NAS-based data to disc using DVDFab on their TVS-882BR without needing a separate computer. -
M.2 SATA 6 Gb/s SSD cache expandability
The TVS-882BR provides two M.2 SSD slots dedicated to caching for increasing IOPS performance. Using an SSD cache boosts overall system performance, and is perfect for improving the overall workflow of random IOPS-demanding applications such as virtualization. Qtier auto-tiring technology automatically moves frequently-used files to SSD and infrequently-used files to HDD for optimal storage performance. -
PCIe slot for diversified storage scenarios
The TVS-882BR provides three PCIe Gen. 3 slot with 1 GB/s bandwidth per lane for diversified storage scenarios. You can install a 10GbE/ 40GbE NIC for network expansion, USB 3.1 10 Gbps adapter to connect with USB devices, compatible Wi-Fi adapter to use the NAS as a wireless access point.
- QNAP TVS-882BR - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 36.99 cm x 31.98 cm x 23.46 cm
- 12.18 kg ()
- Processor
- 1 x Intel Core i7 7700 3.6 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Optical Storage
- 1 x BD-Writer
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- RAM
- 32 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.2
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 36.99 cm
- 31.98 cm
- 23.46 cm
- 12.18 kg ()
- Built-in Devices
- Status LCD, led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- Max Turbo Speed
- 4.2 GHz
- RAM
- 32 GB (installed) / 64 GB (supported) - DDR4
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Optical Storage
- 1 x BD-Writer - 5.25"
- Data Link Protocol
- TCP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP
- VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- 256-bit AES
- UPnP
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 1 (free) x PCI Express 3.0 x8 , 2 (total) / 2 (free) x PCI Express 3.0 x4 , 2 (total) / 2 (free) x M.2 , 4 (total) / 0 (free) x DIMM 288-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 3 x HDMI output , 5 x USB 3.0 - Type A , 2 x audio in - 6.3mm jack , 1 x audio out - mini-jack
- Cables Included
- 4 x network cable
- Audible alarm
- FIPS 140-2
- Included Accessories
- Remote control
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- QNAP QTS 4.2
- OS Required
