With the high transfer speed of DAS and the convenient accessibility of NAS, the TVS-871T is a flexible and efficient storage solution for creative media professionals looking to streamline large 4K video and design workflows. It gives advanced flexibility to deliver performance. It can simultaneously run general Ethernet services in addition to the Thunderbolt 2 network, completely independently and with no bandwidth interference. With dual Thunderbolt 2 ports available, users can flexibly arrange their workstation connections with the TVS-871T and its storage expansion enclosures based on their needs to enjoy high accessibility, optimal collaboration and expansion.
- QNAP TVS-871T - NAS server - 80 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Total Storage Capacity
- 80 TB
- Installed Devices / Modules Qty
- 8 (installed) / 8 (max)
- 29.82 cm x 23.54 cm x 18.52 cm
- Processor
- 1 x Intel Core i7 4790S 3.2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10
- Hard Drive
- 8 x 10 TB SATA 6Gb/s - NAS compatible
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE
- IP Cameras Supported
- 72
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.1.4
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows 7 / Windows 8 (64 bits)
- NAS server
- Host Connectivity
- 80 TB
- 29.82 cm
- 23.54 cm
- 18.52 cm
- Built-in Devices
- Status LCD, led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 16 GB DDR3
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 8 x 10 TB
- Interface Type
- SATA 6Gb/s
- NAS compatible
- Data Link Protocol
- TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Hardware encryption, VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR)
- Encryption Algorithm
- SSL, TLS, FIPS 140-2, 256-bit AES
- UPnP
Security DVR
- 72
- Expansion Bays
- 8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 1 (total) / 0 (free) x PCI Express 2.0 x4 , 1 (total) / 0 (free) x PCI Express 3.0 x8 , 2 (total) / 0 (free) x SO-DIMM 204-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output , 2 x Thunderbolt 2
- Cables Included
- 6 x network cable
- Security lock slot (cable lock sold separately), audible alarm, built-in 2 cooling fans, scheduled power on/off
- Security Slot Type
- Kensington security slot
- FIPS 140-2
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 350 Watt
- QNAP QTS 4.1.4
- Software Included
- QNAP Virtualization Station
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
- Sound Emission
- 23.1 dBA
