QNAP TVS-871T-I7-16G/32TB-RED PRO 8 Bay Desktop NAS
Quicklinx: BYCSWS00 Mfr#: TVS-871T-I7-16G/32TB-RED PRO
  • Core i7
With the high transfer speed of DAS and the convenient accessibility of NAS, the TVS-871T is a flexible and efficient storage solution for creative media professionals looking to streamline large 4K video and design workflows. It gives advanced flexibility to deliver performance. It can simultaneously run general Ethernet services in addition to the Thunderbolt 2 network, completely independently and with no bandwidth interference. With dual Thunderbolt 2 ports available, users can flexibly arrange their workstation connections with the TVS-871T and its storage expansion enclosures based on their needs to enjoy high accessibility, optimal collaboration and expansion.
QNAP TVS-871T - NAS server - 32 TB
NAS server
Host Connectivity
Gigabit Ethernet / 10 Gigabit Ethernet
Total Storage Capacity
32 TB
8 (installed) / 8 (max)
29.82 cm x 23.54 cm x 18.52 cm
1 x Intel Core i7 4790S 3.2 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, 10 hot spare
Hard Drive
8 x 4 TB
10Mb LAN, 100Mb LAN, GigE, 10 GigE
RAM
16 GB
Storage Operating System
QNAP QTS 4.1.4
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows 7 / Windows 8 (64 bits)
NAS server
Host Connectivity
32 TB
29.82 cm
23.54 cm
18.52 cm
Built-in Devices
Status LCD, led panel
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
16 GB (installed) / 16 GB (supported) - DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 10 hot spare
Hard Drive
HDD - hot-swap
8 x 4 TB
Network / Transport Protocol
TCP/IP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, SSH support, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, Apple Time Machine compatible, TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
Encryption Algorithm
256-bit AES
UPnP
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 0 (free) x PCI Express 2.0 x4 , 1 (total) / 0 (free) x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output , 2 x Thunderbolt 2
6 x network cable
Security lock slot (cable lock sold separately), audible alarm, lockable, built-in 2 cooling fans
Security Slot Type
Kensington security slot
FIPS 140-2
Internal power supply
Power Provided
350 Watt
QNAP QTS 4.1.4
5 - 95% (non-condensing)
